Quick brake question - JeepForum.com
post #1 of 11 Old 04-27-2011, 07:13 PM Thread Starter
inlinegrand6
Hi guys I have a wj and fear that I may have to do the akebono calipers soon. What I would like to know is that for all the guys who had teves and swapped for akebono did all your problems go away?? Including warped or heated rotors? Just want to be sure before I fork out the money? Thanks!
inlinegrand6 is offline
post #2 of 11 Old 04-27-2011, 07:19 PM
malibubts
I can't answer about the results as I just ordered my parts, but send Kolak a PM. He has been running a special on Stillen pads and rotors and he can get you the Akebono kit.
malibubts is offline
post #3 of 11 Old 04-27-2011, 07:35 PM
4Tom
fitted akebono kit and new rotors 1 month ago
so far no problems
see http://www.wjjeeps.com/brakes.htm for info.
4Tom is offline
post #4 of 11 Old 04-28-2011, 06:18 AM
RedlegWJ
Yes, they are also easier to service. You won't notice a lot of extra braking, but it does seem to help against over heating. Can't say for certain it works, but another thing I like to do on longer drives or hard breaking is to stop a little short at a light, and creep forward a little so the pads aren't locked on one spot long making a hot spot on the rotor.
RedlegWJ is offline
post #5 of 11 Old 04-30-2011, 06:14 AM
pdpunome
how do i know if i have the akebonos or not?
pdpunome is offline
post #6 of 11 Old 04-30-2011, 07:15 AM
RedlegWJ
Teves will have the external wire spring like the rear.
RedlegWJ is offline
post #7 of 11 Old 04-30-2011, 07:20 AM
mattmc74
2009 JK Wrangler
I have a 99 and I have never had any problems with my front brakes warping rotors or even eatting brake pads! I just put on new rotors and pads this last set off and it was 4 years on the old ones. I don't know maybe I got lucky.
mattmc74 is offline
post #8 of 11 Old 04-30-2011, 11:29 AM
malibubts
Here is a picture of the two side by side. The Akebono is on the left.
@show: And it seems like it's hit or miss issue, some people have issues with them and some never do. If you bought it used it could have been done under warranty before you purchased it.
post #9 of 11 Old 04-30-2011, 12:34 PM
indept
Did the Akebono's in Feb '10. Resurfaced the old rotors when I did it. Over 1 year & still no problems. Before with the Teves, I would have warping within a couple months after new brakes & rotors.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #10 of 11 Old 04-30-2011, 01:30 PM
Kolak
Vendor
Kolak's Avatar
The Teves calipers are overly flexible even when new. Notice the big stiffening bar on the silver Akebono calipers. This keeps the calipers from twisting, resulting in better pad contact during braking. The Teves calipers get worse as they age and the caliper slides get in a bind. The result is rotor hot-spotting and pedal pulsation due to the thickness variation the develops in the rotors.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #11 of 11 Old 04-30-2011, 05:48 PM
mattmc74
2009 JK Wrangler
This is good to know! I will keep an eye on mine and upgrade when I need to. Thanks for the info.
mattmc74 is offline
Quick question.. kcchief77 WJ Grand Cherokee Forum 5 04-22-2011 10:47 AM
Quick question... zachk94 WJ Grand Cherokee Forum 9 04-07-2011 08:03 PM
quick 4.0 question Tbones87 WJ Grand Cherokee Forum 11 03-14-2011 10:00 AM
Quick question novellof WJ Grand Cherokee Forum 1 11-02-2010 08:35 PM
I need quick brake help! McStealth R/T WJ Grand Cherokee Forum 5 03-03-2004 06:02 PM
