quick brake pulsing Q - Page 2 - JeepForum.com
post #16 of 28 Old 05-19-2013, 08:02 AM
lafacej
I also have the pulsing through the steering wheel, I know the rotors are probably warped. Do I need to replace the rotors and the calipers to keep it from happening again?
lafacej is offline
post #17 of 28 Old 05-19-2013, 09:56 AM
SuperStew11
Rotors for sure if they are warped, shouldn't have to replace calipers. Rotors sometimes warp cuz they want to or if the brakes are slammed on a lot you can get build up on the rotors from the pads
SuperStew11 is offline
post #18 of 28 Old 05-19-2013, 10:21 AM
Merc1973
Also make sure the caliper slides move freely and are greased.
Runout is also a major cause of pulsation.
Warping rotors is almost impossible since the casting temps for rotors is about 3x as hot as the hottest during severe braking. It is said they will crack before they warp...
Another cause of pulsation can be if the surface where hub mates to the rotor is not flush. Dont forget uneven lug nut torque...
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #19 of 28 Old 05-19-2013, 11:05 AM
cykaaro
x2 Not properly torquing lug nuts is a very common reason for rotors warping. Braking hard a lot on new rotors can also cause them to warp if you don't give them time to brake in from what I've been told for years from several sources. New brakes I always take ti easy on them for the frist several hundred km's. Unless they're actually defective, or torquing is wrong, I've not had issues.
Strange problem I've been having is I get what seems like badly warp rotors is when I break at highway speeds (100km or so) Slower speeds nothing, and anything above 80km I get vibes on and off. Upper control arms were replaced but lowers still remain to do, and drivers side is bad. (UCA boot on drivers side had a 1/2" split in the rubber across, not from center out) I'm thinking it's the lowers being bad and mimicing warped rotors now that the uppers have bee replaced, and the lowers have soft/worn bushings. The difference is with warped rotors you can notice them at much lower speeds. when braking on the hard side.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #20 of 28 Old 05-19-2013, 12:49 PM
SuperStew11
Just greased my sliders, doesn't seem to have fixed it but noticed my inside pad is half gone on my driver's side caliper and they are only a month old
Any chance that was from the sliders? and do you think with a little time they will wear evenly or should I look at new pads for that side?
post #21 of 28 Old 05-19-2013, 01:23 PM
cykaaro
It could be the sliders, or th piston is seizing. Just had my one caliper sliders greased. Was getting on and off pulling to the right. Figured either the caliper on it's way out or the sliders. One wasn't sliding well, but didn't show signs of bad wear on them. Greased them up and are working fine so far.
What you're describing is what happened to my rear caliper. One side was worn compared to the other. Started to smell bad as it totally seized up. Got if fixed right away. Had to replace the caliper. Would suggest check the caliper is working ok and replace the pads.
cykaaro is offline
post #22 of 28 Old 05-19-2013, 01:27 PM
RIPNBST
If one is half gone look at replacing them.
RIPNBST is offline
post #23 of 28 Old 05-19-2013, 03:17 PM
SuperStew11
One more tidbit, the front brake is making a clicking sound every time it pulses, could that be the caliper all screwed up?
post #24 of 28 Old 05-19-2013, 06:02 PM
cykaaro
Would definitely get it them check out to make sure everything is working ok. Clicking just may be the dust shield or something rubbing, but you never know.
cykaaro is offline
post #25 of 28 Old 05-22-2013, 11:10 AM
SuperStew11
http://youtu.be/z8qfFruZxDw
Here is a quick video of the clicking noise have to turn up the volume a bit, just put a brand new caliper on, starting to think now it mite be the wheel bearing which is a piss off because I just replaced it not to long ago
post #26 of 28 Old 05-22-2013, 11:41 PM
cykaaro
Think your link got messed up there a bit.
Anything possibly rubbing on the dust shield? Never hurts to check the wheel bearing. How's the CV joints?
cykaaro is offline
post #27 of 28 Old 05-23-2013, 12:22 AM
SuperStew11
Ya link only seems to work on my phone app :S
Every thing seems solid, no play in anything and nothing seems to be rubbing, my next guess is the wheel bearing( but turning it by hand I don't hear anything wrong with it)
And nothing out the ordinary with the CV quiet as can be when turning(which is usually when you can tell they are going)
post #28 of 28 Old 05-23-2013, 12:25 AM
SuperStew11
Here's another shot at the video link
Park brake hand brake lever question drystonewalls WJ Grand Cherokee Forum 6 08-03-2013 04:28 AM
Pulsing Vibration in Overdrive UPJeepster WJ Grand Cherokee Forum 2 05-17-2011 06:16 PM
Quick brake question inlinegrand6 WJ Grand Cherokee Forum 10 04-30-2011 05:48 PM
Brakes pulsing Bill08690 WJ Grand Cherokee Forum 2 04-21-2004 02:02 PM
I need quick brake help! McStealth R/T WJ Grand Cherokee Forum 5 03-03-2004 06:02 PM
