quick brake pulsing Q - JeepForum.com
post #1 of 28 Old 02-09-2012, 04:21 PM Thread Starter
jeepvsgti
OK. so i am sure its warped rotors, but i was assuming it was the fronts, since the early wj's have so many issues with the fronts. figured id let it go till it got real bad since they were probably just going to do it again... then i saw this post in another thread:
Originally Posted by jeep04 View Post
Front rotors are normally the cause of the steering wheel shaking while braking, the rear rotors you would feel in the brake pedal more so then the steering wheel.
how reliable of a diagnosis is this? because my pulse is strictly through the brake pedal. 0 steering shake.
would like to figure this out before i haul a trailer next weekend. any other way to be sure which it is?
current: 1999 WJ limited quadradrive
RIP: 1982 CJ7 limited, 1986 2 door 2.8l XJ, 1991 XJ ltd, 2001 XJ, 1998 XJ, 1962 willies wagon
jeepvsgti is offline
post #2 of 28 Old 02-09-2012, 05:14 PM
sfjacks1
Wj
if the pulsing is in the brake pedal and there is no shaking from the sterring wheel when braking, then your rear rotors is where i would start. don't bother turning them, just replace them, they are inexpensive enough..
sfjacks1 is offline
post #3 of 28 Old 02-09-2012, 05:18 PM
USMCBehrensDVLD
id say rear too because i had front warped rotors and the steering wheel shook like a mother ******.
USMCBehrensDVLD is offline
post #4 of 28 Old 02-10-2012, 06:21 AM Thread Starter
jeepvsgti
hmm. that sounds awesome. tossing on some new rear rotors is a lot easier than addressing the crappy front brake setup. thanks.
post #5 of 28 Old 02-13-2012, 08:08 AM Thread Starter
jeepvsgti
hmm. saw on a misc forum that pulling the ebrake a bit will diagnose it. since it only engages the rear brakes, if it still shakes, its the rear, if not, its the front.
any truth to this? when i pull the ebrake lightly, it doesnt pulse. seems kind of hit or miss. like a way to confirm its the rear brakes, if it does pulse... but if it doesnt pulse it could still be the rear?
think ill pull the rear rotors this week and see if the problem goes away. if it doesnt, on to the next step.
post #6 of 28 Old 02-13-2012, 09:44 AM
Double E
Double E's Avatar
I believe the e-brake actually uses an internal-to-the-rotor, shoe-type of system that is not dependent on the hydraulic system. Ergo, the warping may not appear in use of the e-brake system.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 28 Old 04-30-2013, 06:31 PM
SuperStew11
Ok so I'm having the same problem with mine, just replaced the front Disks and seems to have helped a bit but still pulsing. When going into in reverse I can't seem to notice the pulse as much also notice I have a slight leak in my long brake line to the rear brakes any chance that could have something to do with it?
SuperStew11 is offline
post #8 of 28 Old 04-30-2013, 07:33 PM
lazyWJ
2006 XK Commander
My brakes pulse, but I don't feel it through the steering wheel OR the brake pedal. You only feel it in the uneven brake force, especially just coming to a stop. I can't get my head around what that might be. New teves on the front (pads, calipers, rotors) and whatever old junk on the back that probably needs replacing. Anyone ever run into this?
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #9 of 28 Old 04-30-2013, 08:05 PM
brianestep
Dirty fluid = bad pressure?
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #10 of 28 Old 04-30-2013, 08:24 PM
SuperStew11
I could see that, depends on how squishy his peddle,
post #11 of 28 Old 05-01-2013, 06:54 AM
Robertc2012
Did you replace the flexible hose at the caliper.
When old they become restricted not allowing free fluid movement.
Robertc2012 is offline
post #12 of 28 Old 05-01-2013, 09:26 AM
lazyWJ
2006 XK Commander
Pedal feels firm,and no changes in feel or feedback when it's pulsing. I don't know how much fluid was bled through because I didn't do the brakes myself, so it could be dirty. It just feels like there's a sticky spot on the rotor or something that "drags" when slowing down. Seems to be worse when brakes are hot (city driving), so I'm going to check for sticky calipers and probably replace the rears anyway. Not a serious issue, just an annoyance.
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #13 of 28 Old 05-01-2013, 12:13 PM
Robertc2012
Have you checked this.
post #14 of 28 Old 05-01-2013, 12:24 PM
lazyWJ
2006 XK Commander
Flex hoses haven't been replaced since I've owned the jeep for sure, probably original. They bled OK though, no restrictions. I've had bad brake hoses and they've never caused pulsing.
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #15 of 28 Old 05-19-2013, 07:03 AM
SuperStew11
So I replaced my front routers and brakes are still pulsing and getting a bad clicking sound from them too, Anybody have this problem and know what it is?
Park brake hand brake lever question drystonewalls WJ Grand Cherokee Forum 6 08-03-2013 04:28 AM
Pulsing Vibration in Overdrive UPJeepster WJ Grand Cherokee Forum 2 05-17-2011 06:16 PM
Quick brake question inlinegrand6 WJ Grand Cherokee Forum 10 04-30-2011 05:48 PM
Brakes pulsing Bill08690 WJ Grand Cherokee Forum 2 04-21-2004 02:02 PM
I need quick brake help! McStealth R/T WJ Grand Cherokee Forum 5 03-03-2004 06:02 PM
