Quick advise needed on some tires - JeepForum.com
post #1 of 3 Old 03-31-2014, 09:04 PM Thread Starter
lvngtheJEEPlife
Quick and to the point, don't need BS or flaming, running a 2inch bds coil lift, and running if I remember 245/65 17s. Found a good deal on a set of back up tires, but they are 265/70 17. And as far as I remember, or can find, these won't fit. is that correct? Can't find the equation to figure out tire size either otherwise I probably would have answered my own question. Thanks!
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #2 of 3 Old 03-31-2014, 09:33 PM
MuddyWJ
They'll fit with some trimming. 31.5 " I think.
MuddyWJ is offline
post #3 of 3 Old 03-31-2014, 09:39 PM
LarryDallas
Definite trimming. Also, spare won't fit in spare well. Lastly, if using stock rims you'll rub. If you got spacers to clear even more trimming would be needed.
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline
