Question for the Quadra Drive guys - Page 3 - JeepForum.com
post #31 of 35 Old 06-07-2013, 01:38 PM
lazyWJ
2006 XK Commander
Sounds like it's probably working OK, if it wasn't then the rears would just keep spinning. As the front grabs you won't usually see them "spin" rather it just prevents the rear from spinning as much or at all. I like the QD system and I have to say that I even prefer it to my Subarus in the winter, granted it's apples and oranges. I find it has a tendency to understeer unless you drive it aggressively, but once you gain some confidence in the system then aggressive driving is a snap.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #32 of 35 Old 06-08-2013, 06:15 AM Thread Starter
AIRBORNE
Main reason I got the Jeep is due to the winters here. I also live up a huge hill and I slid backwards down it in my Duramax, and was lucky not to wreck. I want something a little better suited to handle the cold months. Fingers crossed that this Jeep does ok
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #33 of 35 Old 06-08-2013, 06:43 AM
TeleBruce
I bought the same Jeep to go TO West VA when it snows. When everything works it as awesome!
I had a similar problem with mine, and would recommend what others have said:
Change the fluid in the transfer case 247 Mopar fluid ONLY and no additives.
Change the fluid in both the front and rear differential with the correct amount of the Mopar friction additive.
It will not be cheap. but you've got all summer to do it.
If the Quadradrive is working for you it's the best around. Unfortunately for me, (or fortunately depending on your viewpoint) I changed the fluid in the transfer case and it was jet black. Previous owner probably never changed it in 10 years. The Quadradrive worked intermittently afterward, and I ended up swapping the tcase with the 242, which is the mechanical one. The reason why I swapped the t case is the clutch parts were $600.00, but a used case with a warranty and drive shaft was half that.
Last year I was ahead of the plows in Canaan :-)
Point is: change your fluids. test it. If the tcase is toast, there are alternatives.
Here's a site that you should keep around. Lots of good info on the WJ series of Jeeps
http://www.wjjeeps.com/
Even with all it's quirks, my WJ is the nicest car I've owned.
TeleBruce is offline
post #34 of 35 Old 06-08-2013, 06:58 AM
-OIIIIIIIO-01
.....Mall Rated.....
-OIIIIIIIO-01's Avatar
Sounds like the progressive clutch, but the whole grass thing has me for a loop. Take it to a shop, they can inform you of your problem quicker than us "yahoo's" (j/k) who can't even see it.
I had the same problem with mine (progressive clutch) and good thing it was under warranty! $$$$ lol.
Good luck!
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #35 of 35 Old 06-08-2013, 09:55 AM
86cj74.2L
86cj74.2L's Avatar
Just remember after the fluid change to do tight figure 8's to purge all the air out of the pumps.
86cj74.2L is online now
