Question for the Quadra Drive guys - JeepForum.com
post #1 of 35 Old 06-04-2013, 08:01 PM Thread Starter
AIRBORNE
I have only maybe logged 100 miles with the GC Limited I bought. I noticed the other day when I mashed the gas it threw gravels with the rear wheels. I looked at the tracks in the gravels and it appeared the rear passenger only spun. I was concerned the AWD isn't working correctly. So I put in the grass and tried the same thing. Could not get a "burnout" mark with the rear wheel again. I have only driven two AWD vehicles ever. How long does it take for the Quadra Drive to engage. Is there a better way to test it? The main reason I bought this vehicle is to drive in the snow. Any advice would be appreciated.
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #2 of 35 Old 06-04-2013, 08:14 PM
lazyWJ
2006 XK Commander
I've never mashed the gas in my jeep. Is it fun? Mine costs me enough already, I don't want to antagonize it. There is a small delay in the transfer case reaction, but not much. The standard advice seems to be to replace the tcase fluid to make sure the type and quantity is correct. If you can get into some mud it should be easier to tell if it's working properly.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #3 of 35 Old 06-04-2013, 08:40 PM
narnwv
narnwv's Avatar
Is it actually Quadra-Drive, or Quadra-Tech II ? If the latter, only one wheel per axle will spin, but once the rear spun enough, the front should engage.
There are plenty of Jeep guys in Morgantown if you want any assistance. You can find most of them on www.jeepinwv.com
~Aaron
narnwv is offline
post #4 of 35 Old 06-04-2013, 10:49 PM
MuddyWJ
I loved my QD in the snow but it worked flawlessly. I tested it by putting it on a lift and the rear wheels spun for about a 1 second before front kicked in. Like lazy said change your fluid and cross fingers.
MuddyWJ is offline
post #5 of 35 Old 06-05-2013, 04:31 AM Thread Starter
AIRBORNE
It's a Quadra Drive. Like I said, in the grass it felt like the front wheels pulled too and could not see where the rear spun out, but in the gravels it didn't look like the front wheels spun.
My Jeep didn't come with owners manual. Where's the guide for what type of fluid to put back into it?
AIRBORNE is offline
post #6 of 35 Old 06-05-2013, 07:56 AM
MuddyWJ
Dealer only NV247 fluid!
MuddyWJ is offline
post #7 of 35 Old 06-05-2013, 08:29 AM
javis4x4
And friction additive too.
javis4x4 is offline
post #8 of 35 Old 06-05-2013, 08:35 AM
USFORCES
Friction additive? Only place you use friction additive is in the rear axle.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #9 of 35 Old 06-05-2013, 08:40 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Actually, both front and rear axles. But definitely NOT the transfer case.
~James
ezflip is offline
post #10 of 35 Old 06-05-2013, 08:54 AM
javis4x4
Why not the TC ? if both axles and TC have the clutches that detect slippage and that's how the system transfers power.
javis4x4 is offline
post #11 of 35 Old 06-05-2013, 09:53 AM
alfaitalia
Because you don't ....that why! Axles only unless you want to Donald Duck your transfer case!
Nowhere if the FSM does it say to put FM in the tc.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #12 of 35 Old 06-05-2013, 10:07 AM
Schlotzky
2007 XK Commander
To the OP; it's a good idea to change the diff and transfer case fluids anyway if you don't know the history of the vehicle, and if you indeed have QuadraDrive and not QuadraTrac, you should be getting pretty good power transfer from side to side--at least in the back. It's possible that the previous owner added too much friction modifier to completely quiet down the moaning you sometimes get on tight, cold turns, but it impedes the function of the differentials. Change out your diff fluid front and rear with synthetic 75w140 and add FM only until the moaning and chattering is tolerable for you (the factory recommendations will eliminate moan and chatter under all conditions once the diffs are warmed up, and allow a bit of moan when they're still cold on full-lock turns). The less you add, in theory, the better the diffs will lock when you ask them to. Change the transfer case with the dealer fluid if for no other reason than preventative maintenance. It's advised to be changed a whole lot more than your average used car owner would change it (every 30k miles).
Schlotzky is offline
post #13 of 35 Old 06-05-2013, 10:16 AM
Zimboo22
I thought you only put Limited Slip in the front, am I wrong on that one?
Zimboo22 is offline
post #14 of 35 Old 06-05-2013, 10:23 AM
85IrocZ-28
If you have varilock differentials front and rear, you need to add FM front and rear. The factory spec is 2.5 fl oz front, and 4.0 fl oz rear of Mopar Friction Modifier. I use ONLY MOPAR friction modifier in my diffs, and MOPAR ONLY t-case fluid in the 247 and have good results at 135K on the clock, running 35 inch tires for over half of those miles.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #15 of 35 Old 06-05-2013, 10:37 AM
javis4x4
How do your verilocks work with 35 inch tires, I had read that the biggest tire to run with verilocks is a 31in and 32in @ the biggest ?
javis4x4 is offline
