Question about steering wheel.... - JeepForum.com
post #1 of 4 Old 03-15-2010, 04:28 PM Thread Starter
kwb18
2011 WK
I put on a new SS and my wheel was a little off center to the right. I needed an alignment anyways so I took it to a shop. They told me that the adjusting sleeve was stripped. ??? And pretty much just walked me out the door. So I get back in my Jeep and now the wheel is completely off center to the left. Now I'm confused with the shop.
I know there is a way you can adjust the wheel. I read on here it's the drag link? I loosened up the two clamps and attempted to turn it by hand and it's not budging. Maybe I'm doing something wrong. I heard it's suppose to turn by hand and you don't need much turning to get the wheel back. So what am I doing wrong? Thanks guys!
kwb18 is offline
post #2 of 4 Old 03-15-2010, 04:32 PM
sdowney717
it better not be stripped.
If you drive it and it is stripped, it might come apart.
Yes you turn the drag link sleeve to center the wheel. If it is clean and greased, you can turn it by hand.
I never seen one stripped yet.
sdowney717 is offline
post #3 of 4 Old 03-15-2010, 04:37 PM Thread Starter
kwb18
2011 WK
Well the funny thing is they put on a new TRE at the pitman arm and that seemed completely fine. I just don't see how if it was stripped how they would get that tre on and then why would my wheel be off to the other side? I honestly just don't think the shop knew what they were doing or they were just in a hurry.
Do I just get a pipe wrench and loosen up those clamps and twist it until it's back to center?
kwb18 is offline
post #4 of 4 Old 03-16-2010, 05:39 AM
sdowney717
yes, you can turn it with any tool you can imagine will work.
I would spray it with some pb blaster if it is rusty.
Also, I tend to take things like this apart and put grease on them so they dont ever get stuck. Simply unscrew it somewhat and grease it up, fill the slot with grease, etc...then screw it back down to center the wheel.
steering wheel question joshjones84 ZJ Grand Cherokee Forum 2 02-26-2010 07:35 AM
Steering Wheel Question! KWAG ZJ Grand Cherokee Forum 0 03-19-2009 11:01 PM
Steering Wheel Question jeeper31 WK Grand Cherokee & XK Commander Forum 10 01-03-2008 05:43 PM
Steering wheel question, 1998 ZJ doccjp ZJ Grand Cherokee Forum 3 03-13-2005 11:31 AM
Steering Wheel Audio Controls Question Roadrunr ZJ Grand Cherokee Forum 1 01-08-2004 11:59 PM
