-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Question about bleeding (http://www.jeepforum.com/forum/f310/question-about-bleeding-1542839/)
Ckess22 06-29-2013 01:56 PM
I hv 2004 v8 cherokee w a defective water pump and thermostat. I thought I could replace this myself, but halfway in I realized I need an impact wrench (which I'm not going to buy...I'm not mechanical and won't use it but this once) to get the pump bolts off. So, I need to drive my car about a mile to the repair joint.
Should I a.) leave the drained coolant out for that short drive or b.) refill it, not knowing if I can properly go through the bleed process bc my water pump is jacked. In case it's not obvious, I'm in over my head and just need some solid advice. Thanks.
Paradise XJ 06-29-2013 03:52 PM
Put water in it, or coolant if you have saved it Take it to the shop. Don't bother bleeding anything.
Now don't take this the wrong way, but, then go the GRAND Cherokee forum. There's no such thing as an 04 V8 Cherokee...unless it's a Grand.
...and why would you need an impact wrench to remove a water pump??
chris87xj 06-29-2013 04:47 PM
I'm going to move this thread over to the Grand Cherokee section of the forum, but let me know if I've miss the target on this one.
ezflip 06-29-2013 05:00 PM
Honestly, with the V8, if you have pump issues and have already drained the coolant, have it towed to the shop. Unless its literally right around the corner. I wouldn't drive it at all with a bad water pump. With the problems that come with overheating the aluminum heads of the V8, dont even chance it. And for the record, there is no reason at all you should be using an impact wrench on the water pump.
Jer-Bear 06-29-2013 05:40 PM
Hey man, you don't need anything except for wrench to remove the water pump bolts. I did water pump and thermostat with simple hand tools. Save money and DIY!
Ckess22 06-29-2013 06:39 PM
Thanks for the help. And yes, it's a grand cherokee. Ok, so am I just being a wuss? I couldn't get the bolts to budge? What kind of wrench do I need to get it off?
Ckess22 06-29-2013 06:40 PM
If I could get the bolts off, I'd have this done.
Ckess22 06-29-2013 06:46 PM
So yeah, I was just being a wuss. Ok, so in the video I watched on doing this, it said I needed to be sure to put the new bolts in to ' manufacturers specifications'. Another amateur question, but how do I do that? Should I just tighten them up as I would any other bolt and call it good? Thanks again for the help.
Not new bolts...old bolts on the new water pump...
narnwv 06-29-2013 08:51 PM
You should be fine just making them "muscle tight", as long as the RTV is on there properly.
Please fill out your Jeep profile so we know what you're working with.
Jer-Bear 06-29-2013 09:07 PM
I'd tighten them down pretty good, but not enough to crush the gasket. You want them tight to make a good seal, like a valve cover.
ezflip 06-29-2013 10:01 PM
Or, buy yourself a torque wrench and torque them down to 43 ft-lbs.
4x4fvr 07-01-2013 11:46 AM
You can use a piece of pipe on any rachet handle for leverage to break them loose. 43 ft/lb is muscle tight when reinstalling
The time now is 05:04 AM.
