Quadradrive vs quadratrac2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Quadradrive vs quadratrac2
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 04-19-2011, 11:42 AM   #1
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Whats the differences between These two systems? Which one is best?
2000 Grand Cherokee Limited ¤ 4.7 Low output V8 ¤ 545RFE ¤ Quadradrive ¤ Shale Green Metallic ¤ Agate/Carbon interior ¤ Viper 5704 alarm/remote start ¤ Alpine HU ¤ Rockford Fosgate P500-4 +P500-1bd ¤ 4X Infinity Kappa 60.9CS +1X 100.9W ¤ Rugged Ridge floor mats ¤ LED interior light ¤ Tinted windows ¤ Grill mesh mod ¤ Spyder halo headlights ¤ Spyder halo foglights ¤ 6" Hella`s 500 Black magic Lights ¤ Debadged ¤ Rear Wiper Delete ¤ Spyder LED taillights ¤ Smoked LED third brakelight ¤ LED licence plate light ¤ Saguaro 3/4in recovery shackles ¤ 3" Kolak exhaust Magnaflow cat Flowmaster 70 muffler ¤ Superchip ¤ TM snip mod ¤ 2" BDS springs ¤ Bilstein 5100 shocks ¤ Addco swaybars ¤ JKS trackbar ¤ JKS front discos ¤ IRO rear ext endlinks ¤ Moog super trial boss SS ¤ BTF Cryptonite diffcovers ¤ Stillen Rotors/Black matrix pads ¤ Pro Comp 17`s Helldorado Machined polished w/General Grabber AT2 255/70/17 ¤ JK Sahara 18`s w/Nokian Hakkapelitta R SUV 255/60/18 ¤ Urban Assault Vehicle
We dont care how they do it in Japan!
Buildthread ¤ http://www.jeepforum.com/forum/f197/...orway-1193503/ ¤
Thomahawk is online now   Reply With Quote
Unread 04-19-2011, 11:54 AM   #2
AGDubyaJ
quadradrive uses vari-lock differentials front and rear (limited slip). quadratrac does not.
98 ZJ- 4.0L, NP242, has a DVD player!!! bone stock for now.
77 FSJ- 360, 4speed, D20, summit rv cam, 4bbl weber carb, headers, work in progress- resto/DD, hauls balls...
69 Chevy K/10 4x4- 350, 4 speed, lots of power!
AGDubyaJ is offline   Reply With Quote
Unread 04-19-2011, 12:06 PM   #3
Mr_Grumpy
www.wjjeeps.com is the bible for these things
Mr_Grumpy is offline   Reply With Quote
Unread 04-19-2011, 02:52 PM   #4
1AAdam
the wood has an 01 limited with the quadradrive and it is pretty freaking great! everything is super automatic and it has front and rear hydraulic lockers from the factory! my icy driveway here in new england is not match for it all winter and u don't have to shift it!
Adam
1aauto.com
888-844-3393
1AAdam is offline   Reply With Quote
Unread 04-19-2011, 03:05 PM   #5
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
I know the qd is ****ing awesome. I have one myself and pushing snow here in Norway every winter. Its great fun. My brother in law Are going to by a wj now. Therfor asking. So i understand the main differences Are the varilooks in rear and front diff. Anything Else? Is the quadratrac2 only ****?
Unread 04-19-2011, 03:27 PM   #6
4Tom
http://www.wjjeeps.com/tcases.htm
4Tom is offline   Reply With Quote
Unread 04-19-2011, 03:32 PM   #7
Wjason
Yep that's the difference, same 247 case. The differentials are special which also means they have special length axle shafts and carrier (not interchangeable with regular D30). Also QD WJs have a D44a rear not a D35. Quadratrac could be either depending on engine / tow package.
Wjason is offline   Reply With Quote
Unread 04-19-2011, 11:06 PM   #8
billzcat1
Chicken in a Turkey Suit
2003 WJ
From the FAQ:
Originally Posted by billzcat1 View Post
There's a lot of folks who don't understand their 4WD systems so I'm posting it here. Most of this info is also available on www.wjjeeps.com but no one seems to read it, so here it is. More detailed information and information on axles available here: http://www.wjjeeps.com/tcases.htm
Selec-Trac
Primarily found in Laredo, Special Edition, Freedom Edition, and Columbia Edition
Transfer Case: NV242J (I6) or NV242HD (V8)
Transfer Case fluid: ATF+4
Operating Modes
2WD: rear wheel drive only
4 Part Time: locks front and rear axles together, do not use on paved surfaces as it can cause damage to drivetrain components. Off road/snow only!
4 Full time: powers front and rear axles but allows slip between them through use of a center differential. This can be used on any surface or condition
Neutral: allows flat-towing as the transfer case is disengaged from the transmission
4 LO: Locks front and rear axles together just like 4 Part Time, but also adds a 2.72:1 gear reduction, giving you 2.72 times more torque at the wheels but makes your Jeep 2.72 times slower. Not recommended for use above 25mph. Also, not for use on paved surfaces. Off road/snow only!
Editorial Notes: Selec-Trac is the most desired 4wd system for off-road use because of the numerous modes offered by the NV 242 transfer case and the fully-locked 4HI mode. This is desirable for situations where you need lots of wheel speed to keep forward motion, such as snow-wheeling or in deep mud. This transfer case is also quite reliable but occasionally has trouble shifting between modes. Often, a fluid flush helps improve this.
Also, with open differentials front/rear, you have the option of easily installing lockers or limited slip differentials. The Dana 30 and Dana 35 differentials have many options from the aftermarket community, but the Dana 44a only has a few options for lockers.
QuadraTrac-I
Found only on 2004 Laredo I6 models (optional)
Transfer Case: NV147
Transfer Case Fluid: Mopar NV245/247/249 fluid, P/N 05016796AB
Operating Modes
None! The transfer case in this 4WD system is permanently in "4 HI". It uses a gerotor-driven hydraulically operated clutch pack to transfer power from front to rear. It operates just like the more-common NV247 transfer case but does not offer a neutral or low-range selection. This 4WD system will operate as a RWD system until the rear axle slips, at which point the transfer case will send power to the front axle.
Editorial Notes: This 4WD system epitomizes the unfortunate "soccer mom" image that the WJ sometimes carries. Since it offers no low range selection, it is the least desirable 4WD system for off-road use but should still provide good mobility on-road in wet or snowy conditions.
Quadra-Trac II
Found in Laredo and Limited models, standard equipment for V8 models.
Transfer Case: NV247
Transfer Case Fluid: Mopar NV245/247/249 fluid, P/N 05016796AB ONLY
Operating Modes
4 All-Time: Uses a gerotor-driven hydraulically-actuated progressive clutch pack to transfer torque to the front axle. Under normal conditions, the unit operates in RWD but transfers torque to the front axle once wheel spin occurs. Suitable for use on all surfaces/conditions.
4 LO: Locks front and rear axles together and disengages the progressive coupler. This also adds a 2.72:1 gear reduction, giving you 2.72 times more torque at the wheels but makes your Jeep 2.72 times slower. Not recommended for use above 25mph. Also, not for use on paved surfaces. Off road/snow only!
Editorial Notes: Quadra-Trac II is a common 4WD system in the WJ and offers "point and shoot" functionality... kind of the "4WD for dummies" system. Not to say it isn't capable, though. With the same 4LO function as Selec-Trac, there are very few situations where Quadra-Trac II will be inadequate.
The NV247 transfer case is generally reliable, but unfortunately does have occasional issues with the progressive coupler used in 4 All-Time. Most service documentation lists ATF+4 as the correct fluid for it, but this is incorrect and Chrysler published a TSB about it. ATF+4 will cause premature wear and binding in the transfer case and will eventually cause destruction of the case. If the coupler fails, then the vehicle will be in RWD mode unless you engage 4 LO.
With open differentials front and rear, the same locker/limited slip options mentioned for Selec-Trac are available.
Quadra-Drive
Special Order for Laredo, Optional for Limited, Standard on Overland
Operating Modes
Editorial Notes:Quadra-Drive is the "top-of-the-line" 4WD system offered by Jeep for the WJ. It uses the same transfer case as Quadra-Trac II but added limited slip differentials front and rear called "Vari-Lok". These operate on the same principles as the transfer case, only instead of transferring torque front to rear, they transfer side-to-side. This means you truly have 4 driven wheels with QuadraDrive, something not offered on any of the other 4WD systems. Unfortunately, the same reliability and fluid-compatibility issues from Quadra-Trac II affect Quadra-Drive so transfer case failures are possible.
Off-road, the Vari-Lok differentials give tons of traction and often help the WJ hang with more-built rigs. They function better than most other limited slip differentials because they will lock fully and also operate with one wheel in the air. Unlike the older Trac-Lok differentials offered by Jeep, they operate with virtually no wear and also offer considerably more torque-holding power.
One disadvantage: the VariLok differentials require Mopar friction modifier with their gear oil, making maintenance slightly more expensive. If the wrong amount of friction modifier is added, the differential will either bind or slip too much. Redline's 75W140 gear oil has the proper amount pre-mixed, as does Royal Purple MaxGear. Other oils have *some* friction modifier already added but not enough so you'll have to add a little more until it doesn't bind.
QuadraDrive has one other disadvantage - by adding VariLok differentials, Jeep changed the differential carriers and axle shafts for front and rear differentials. This makes installing any other locker/limited slip impossible without procuring the appropriate parts from a Quadra-Trac 2. If you MUST have a locker, start with a Quadra-Trac II or Selec-Trac vehicle. However, most users of Quadra-Drive are very happy with their operation.
Quadra-Drive II was not available on the WJ. Ever. It was offered on the 2005+ WK Grand Cherokee and is similar to QuadraDrive but added electronic control to the transfer case and differentials...which is either good or bad depending on your point of view. Anyway, when you say your WJ has Quadra-Drive II, you lose all credibility.
billzcat1 is offline   Reply With Quote
Unread 04-19-2011, 11:55 PM   #9
FinJeep
WJ
I wonder what they were thinking of when they came out with NV247. Quadra Drive is nice but Selec-Trac with Vari-loks would've been even better.
I also wonder why it took until 1999 before the legendary Jeep got LSDs on both axels for the first time, and why it took until 2003 Rubicon before Jeep got its first real four wheel drive with lockers on both axles (please correct me if I'm wrong).
FinJeep is offline   Reply With Quote
Unread 04-20-2011, 02:11 AM   #10
outlaw30
I believe all QT II have a D44a. Its the Selectrac that can be had with a D35 rear, depending on whether V8 and/or tow package.
outlaw30 is offline   Reply With Quote
Unread 04-20-2011, 02:26 AM   #11
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Ok Thanks alot guys. See the differences in limited slip diff axels and tow capasity. Understand this now. Thanks again.
Unread 04-20-2011, 04:22 AM   #12
outlaw30
tow capacity is changed with QTII and QD? I don't think so...its D35 vs D44a (and the engines/transmission/tow packages they come with) that determine tow capacity.
Unread 04-20-2011, 05:08 AM   #13
86cj74.2L
86cj74.2L's Avatar
I think a lot of the reasons why it took so long to get a factory option for the front axil is they finally developed something that won't cause drivability problems when making tight turns in snow and ice.
My cummins with open diffs and the 1100lbs engine over the front axil is *ell making a sharp turn from a stop in snow deeper then 5 inches. all it wants to do is go strait. I usually pull out in 2wd and then shift to 4wd when rolling in those situiations. If I am on a hill and stopped in 4wd I need to bob the throttle to get it to turn sharp enough to make it.
With the 247 it does that for me I do not need to think about it (or my wife).
I also wish the Varilock was avaliable in the D60 and D70/80.
86cj74.2L is offline   Reply With Quote
Unread 04-20-2011, 11:31 AM   #14
1AAdam
that would be great! i would love the LSD's on my selectrac! possible swap??
Adam
1aauto.com
888-844-3393
Unread 04-20-2011, 01:03 PM   #15
billzcat1
2003 WJ
It's easier to start with a QuadraDrive and swap the NV242 transfer case than it is to swap the pair of QuadraDrive axles.
