Quadradrive transfercase problem - JeepForum.com
post #1 of 2 Old 10-10-2010, 11:59 PM Thread Starter
Colt737
Wj Quadradrive transfercase problem
Ok so I tested once again the shifting from 4wd all time to 4LO, I know your supposed to be in nuetral and let the jeep roll 1-3mph forward. Well, I tried this and now it sounds like gears grinding and I can feel the vibration through the shifter when I try to shift to 4LO. It feels and sounds so bad it seems like the engine will fall apart if I try to force it. It has been a few years since I put the Jeep in 4LO.
I hope a transfercase flush will fix this problem. If anyone has any input I appreciate it. Thanks.
2004 Jeep Grand Cherokee Overland
Colt737 is offline
post #2 of 2 Old 10-11-2010, 04:09 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
pull it back with authority. If you half butt it, it will grind a lot.
ratmonkey is offline
2002 Overland Quadradrive what axles?? Bubba3200 WJ Grand Cherokee Forum 8 09-04-2010 10:53 PM
Can i take Fr. Driveshaft out of 99 WJ Limited Quadradrive bigredjeep95 WJ Grand Cherokee Forum 7 07-29-2010 07:02 PM
Varilock on the Quadradrive Q ultimo WJ Grand Cherokee Forum 17 04-14-2010 09:59 PM
lazy quadradrive trek96 WJ Grand Cherokee Forum 1 11-01-2003 07:18 AM
Quadratrac ll to Quadradrive krork WJ Grand Cherokee Forum 2 10-27-2002 08:37 PM
