Quadradrive or Quadra-Trac? - JeepForum.com
post #1 of 26 Old 07-09-2013, 08:00 AM Thread Starter
tkcarp01
Hey guys. I've had my '99 GC Limited for about a year now... Traded my bike for it, and couldn't be happier. It has had several little things I have been working on... Still need to pull a rear axle to fix a slow seal leak, but the latest little gremlin is a tick in the front driver's side, especially when turning. Looks like the boot on the CV joint is completely tore, so I'm thinking time to replace. I think I have the Vari-lock axles... But I can't figure out of I'm Quadradrive or Quadra-Trac... I have the 247 transfer case, which is apparently in both... Any help? It is a 4.7, and I can't find a badge anywhere...
tkcarp01 is offline
post #2 of 26 Old 07-09-2013, 08:01 AM
narnwv
narnwv's Avatar
what's it say on your shifter bezel?
~Aaron
narnwv is offline
post #3 of 26 Old 07-09-2013, 08:18 AM Thread Starter
tkcarp01
4 All-time, N, and 4-lo. No badge indicating type.
tkcarp01 is offline
post #4 of 26 Old 07-09-2013, 08:22 AM
Jeeples
Jeeples's Avatar
Usually at the bottom of the bezel it will indicate which 4 wheel drive system you have:
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 26 Old 07-09-2013, 08:24 AM Thread Starter
tkcarp01
Yeah... I have nothing. Which leads me to think maybe Quadradrive, and the raised badge got ripped off, since the Quadra-Trac II is painted on?
tkcarp01 is offline
post #6 of 26 Old 07-09-2013, 08:32 AM
Jeeples
Jeeples's Avatar
Possibly, however the printed on lettering could be rubbed off too.
Any badge on the rear hatch denoting Quadradrive? Might take a peek at your rear diff cover and see if you have a tag that calls for limited slip additive to be used when servicing the diff.
Aside from that you may need to send a request for your build sheet.
Jeeples is offline
post #7 of 26 Old 07-09-2013, 08:42 AM Thread Starter
tkcarp01
Nothing on the rear hatch, either. I've noticed one side has been reprinted at some point, and the front driveshaft is from a boneyard (has paint pen lettering on it denoting what it is). No tag left on rear diff.
Where and how do I request my build sheet? The link in the stickies is broken...
tkcarp01 is offline
post #8 of 26 Old 07-09-2013, 08:48 AM
Jeeples
Jeeples's Avatar
Here ya go, its a little hard to find on the website, but this should do it:
http://www.jeep.com/wccsapp/universal/J/index.jsp
If that link doesn't work for some reason: www.jeep.com > Owner's Center > Contact Us > Customer Assistance > Send Us An E-mail
Jeeples is offline
post #9 of 26 Old 07-09-2013, 12:31 PM
its-me-B
I thought the 4 hi n 4 lo was the quadradrive, and the quadra-trac as part time 4 hi and 4 low...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #10 of 26 Old 07-09-2013, 12:41 PM
narnwv
narnwv's Avatar
Negative. Quadra-Trac II/Quadra-Drive use the same 247 transfer case, therefore, both have 4hi-ALL TIME, N, and 4-LOW (part time).
~Aaron
narnwv is offline
post #11 of 26 Old 07-09-2013, 01:42 PM
its-me-B
your right... I just remembered looking at your post. thinking the 242 I was.
its-me-B is offline
post #12 of 26 Old 07-09-2013, 01:44 PM Thread Starter
tkcarp01
Thanks guys! I'll see about getting that build sheet...
On a related note, I got all CSI on my shifter and found a small spot of adhesive residue on the bezel where the Quadradrive emblem should be... Makes me think it was the raised emblem and not the painted on Quadra-Trac.
tkcarp01 is offline
post #13 of 26 Old 07-11-2013, 01:24 PM Thread Starter
tkcarp01
The plot thickens...
Just reviewed my build sheet from Chrysler. Sad to say this is the first build sheet I've ever had for a vehicle of my own... Very cool to see just what went into my WJ.
Anyway, one of the early items on the sheet is: AWB Quadra-Drive II (R) 4WD system.
But then, later is: DHFP Quadra-Trac II on Demand 4wd system.
And after that, it lists front and rear Vari-lock axles. So... What do I have?
And, on an unrelated note... What exactly is ADEP Cold Weather Group? Does that pretty much just amount to heated seats?
tkcarp01 is offline
post #14 of 26 Old 07-11-2013, 01:39 PM
Jeeples
Jeeples's Avatar
Post up a copy of the sheet if you can. It sounds like you have Quadradrive, since the Vari-Lock axles are listed on your build sheet. It probably lists the Quadratrac case as it may be part of an option group that was standard, but subsequently removed as part of a different option group.
Not sure on the cold weather group.
Jeeples is offline
post #15 of 26 Old 07-11-2013, 01:42 PM Thread Starter
tkcarp01
On it!
We are pleased to provide vehicle build information per your request for
your vehicle. According to our records, your vehicle was equipped from
the factory with the following:
Sales Code Description
*DL Prem Leather Trimmed Bucket Seats
-AZ Agate
ADBP Protection Group
AFFP Luxury Group
AHX Trailer Tow Group IV
APAS Monotone Paint
ARPP Limited Decor Group
ATA Radio - Cass/10-Disc./Infinity Spkrs
AWB Quadra-Drive II (R) 4WD System
AWS Smoker's Group
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZS 136 Amp Alternator
BC6S 625 Amp Maintenance Free Battery
BRYS Anti-Lock 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CBWS Highline Door Trim Panel
CFNS Rear 60/40 Folding Seat
CGWS Next Generation Front Air Bags**
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKRP Cargo Net
CKTS Cargo Tie Down Loops
CLEP Front & Rear Floor Mats
CLGP Covered Cargo Storage
CLPS Driver Foot Rest
CSCP Cargo Compartment Cover
CSRS Passenger Assist Handles
CUDP Mini Overhead Console
CUFS Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DG4S Multi-Speed Auto 45RFE Transmission
DHAS Lock-Up Torque Converter
DHFP Quadra-Trac II On Demand 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
DSBP Vari-Lok Progressive Front Axle
DSCP Vari-Lok Progressive Rear Axle
EAAC All Engines
EVA 4.7L V8 Power Tech Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEPS Flipper Liftgate Glass
GFAS Rear Window Defroster
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GT3P Power Heat Driver Auto Dim Mirrors
GWAP Power Sunroof
GXMS Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAFP Air Cond ATC w/Dual Zone Control
HGAS Hood Insulation
HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJAP Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Rear Auxiliary Power Outlet
JKAS Glove Box
JKPS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JTFP Power 10-Way Heated Memory Seats
KEDP Lt. Quartz - Paint Stripe - Bodyside
KRSS RADIANT SILVER - DIM GRAPHIC - "4X4"
KSSP RADIANT SILVER - Badge
KTSS RADIANT SILVER - "JEEP" Badge
KUSP RADIANT SILVER - Badge
KWSS RADIANT SILVER - Badge
K4RS FLAME RED CLEAR-COAT - CLADDING
LACS Illuminated Entry
LAGS Warning Chime
LAZP Vehicle Information Center
LBBS Courtesy Lamps
LBCS Glove Box Lamp
LBDS Ash Tray Lamp
LCBP Door Courtesy Lamps
LCES Rear Courtesy/Reading Lamps
LDAS Underhood Lamp
LDBS Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LEWP Radio/Driver Seat/Mirror Memory
LMBS Halogen Headlamps
LMGP Automatic Headlamps
LNJP Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MDAP Front License Plate Bracket
MFTP Body Color Grille
MHAS Black Windshield Moldings
MWGS Side Roof Rails
MZBP Quadra Drive Badge
NAEP California Emissions
NBN Northeastern States Tracking
NBVP Low Emission Vehicle (LEV)
NFPS 20.5 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHMS Speed Control
PR4 Flame Red Clear Coat
QR4S Flame Red Clear Coat
RAAC All Radio Equipped Vehicles
RBNP AM/FM Cass Radio w/Changer Control
RCEP Infinity Speakers
RDDS Fixed Long Mast Antenna
RDPP 10-Disc Remote CD Changer
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Steering
SCLP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBGS Compact Spare Tire
TBLS Inside Mounted Spare Tire
TTDP P245/70R16 BSW AS Perf Tires
TZAS Goodyear Brand Tires
WDRP 16X7.0 Lux Alum Silver Wheels
WFBS Compact Spare Wheel
WLZC All Aluminum Wheels
XGDP Universal Garage Door Opener
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
Our records indicate that the following recall campaigns have not been
performed by an authorized dealer:
882 - REPROGRAM PCM OBD READINESS CODES
839 - REPROGRAM PCM OBD
We suggest that you contact your local authorized Chrysler, Dodge, Jeep®
or Ram dealer to make arrangements for an inspection and, if necessary,
corrective action at no charge to you.
Please take a copy of this message with you at the time of service to
aid the process. Although not required, it is recommended to bring a
copy of the recall notification with you to your dealer's service
department when you bring your vehicle in for this service.
If you wish to obtain further information, please contact the Chrysler
Group Recall Assistance Center at 1-800-853-1403.
Thanks again for your email.
Sincerely,
Christopher
Customer Service Representative
Jeep Customer Assistance Center
tkcarp01 is offline
