Quadradrive Front Axle Swap to Quadratrac Front Axle Possible? - JeepForum.com
post #1 of 6 Old 12-27-2011, 03:06 PM Thread Starter
bigredjeep95
Wj Quadradrive Front Axle Swap to Quadratrac Front Axle Possible?
I have a 99 WJ 4.7 Limited with quadradrive and Vari-lok axles, can i swap to quadratrac full assembly so long as i use the same gear ratio?
The popping in my front is horrible, both axle boots have been torn for a while and the hydra-lok diff is chattering pretty bad. I just wanna swap the front over to quadratrac to eliminate the front hydralok , its expensive to replace. If i replace the shafts and the hydralok still chatters i'd be pissed. So i'll replace the whole unit, the parts place by me has 2 Quadratrac and 2 Quadradrive Front Axles for $400 each, all around 100K miles. This is just for a daily driver. Also is the Quadratrac front driveshaft a Rezeppa shaft or a U-Joint Shaft?
95 YJ Wrangler - 35" Swamper SSR's, 4.5" Rubicon Express Lift Spring with Spring Over, 4.10 Gears, Ford Dana 44, Ford 9", M8000 Winch
1995 YJ Wrangler- 2.5, 2" Lift 31" Tires
1975 Cherokee S Widetrack, 6" Lift, 35" Baja Claws, AMC 360
2012 Chevy 2500HD 4x4 6.0
2002 WJ Grand Cherokee Limited, AFE Intake,DD
1990 YJ Wrangler - Torn Apart
bigredjeep95 is offline
post #2 of 6 Old 12-27-2011, 04:40 PM
85IrocZ-28
I don't have an answer about part swap compatibility, but have some other thoughts.
Personally, I really like the QD2 setup and the varilocks. They are great for the winter driving here in Utah, and do very well offroad. Replacing the axle shafts isn't too hard. And if there is chatter in the diff, add some friction modifier. That should fix your problem. If you swap to another setup, you will need to have the gears and pinion set properly. Unless you have the tools and experience, it will be expensive to have the gears set. You can't just bolt the parts in, they need to be shimmed and adjusted for the new axle housing they are going into.
In regards to your shaft, just get under and look. The Repezza has covered CV's on each end. The double cardan has a single U-joint on the axle Double U-joint uncovered CV on the t-case end. My Quadradrive II had a double cardan shaft when I bought it, but it could have been changed out.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #3 of 6 Old 12-27-2011, 04:42 PM
xJoshxx
2012 WK
Yes you can just make sure the gear ratio's are the same.
You can't put 3.55's up front and 3.73 rear.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #4 of 6 Old 12-27-2011, 05:21 PM
kristi5683
400 each axle? thats a bit high... have they replaced anything on it? (like the pinion seal, shaft seals etc)
I dont know if all quadra tracks have the same front drive shaft but mine came with the double cardan. I think it varies with the year. All you would have to do is change pinion yokes to make yours fit im pretty sure.
I've got extra replacement differentials and an extra set of shafts if you wanna save a little. I'm not sure how much it costs to get diffs installed though.
I would honestly check your local junkyards for an axle cause 400 is awful high unless its literally ready to bolt on with all new seals and everything checked.
kristi5683 is offline
post #5 of 6 Old 12-27-2011, 08:33 PM Thread Starter
bigredjeep95
I'm talking about the whole front assembly from brake to brake and housing. Yes i can do my own gearing, my friend has a press,and the yukon bearing puller sockets, they work great.
post #6 of 6 Old 12-27-2011, 09:03 PM
kristi5683
well I've got my set from my old axle with shafts. (non varilock) and I've got another set with shafts that are varilock. both carriers are for 3:73 and up.
If you're interested let me know.
on a side note though, have you tried rebuilding your cv joints? since your boots are torn, there may be debri in there that's causing the noise, or at least contributing to it.
99 WJ Front Axle shaft replacement (Quadradrive) BHand89 WJ Grand Cherokee Forum 10 03-01-2011 08:12 PM
I am going with 9'' rear swap. will 9'' front axle work for wj also? Big-Z WJ Grand Cherokee Forum 6 01-23-2011 11:37 AM
Front axle: Polished D30 vs. D44 swap StrokedWJ WJ Grand Cherokee Forum 27 01-15-2011 11:50 AM
Front Axle Swap Mud_Crazy WJ Grand Cherokee Forum 13 11-03-2010 11:04 AM
WJ V8->I-6 front axle swap dkpulsford WJ Grand Cherokee Forum 3 05-17-2010 12:02 AM
