Quadra-Trac vs Quadra-Drive - Page 2 - JeepForum.com
post #16 of 49 Old 09-20-2005, 09:05 PM
Bob_V
****** bump
Bob_V is offline
post #17 of 49 Old 09-22-2005, 08:28 AM
2Grand4s
What the *#%@#* is Quadra Drive # 2 ? ?
My 04 Overland has Quadra Drive ( assume that means version # 1) with vari-lock front and rear axles. What did they add to make it different ? Is the QT2 transfer case different in 06 than it was before ? Hopefully not some electronic gizmo from Inspector Gadget than will fizzle-out when you need it most ! If had wanted that I'd be driving a Honda Pile-of, or the Alabama-Benz !
Ed . . .owner of 2 Grand's, a 94 Limited V-8 w/Up-Country and a '04 Overland 4WD
205,000 miles on the '94, 2500 Miles on the '04
2Grand4s is offline
post #18 of 49 Old 09-22-2005, 09:30 AM
Jetjock16
Hello guys, im new, and ive been out of jeeps for many years, but now my wife wants an 01/02 Grand.... My last one was a 94 Grand 4x4, with V8, back then you could not get the V8 with selectable 4x4/4x2... is that still the case for these? im looking at used rigs, i have learned allot from your posts.. is there any versions with V8 in 01/02 where you can run in rear wheel drive, and then select 4x4, this would save on gas, and front u-joints, but since it will be for my wife, i guess id probably rather have the All time 4x4/AWD.... just trying to learn... Soo from this post, which is better in my shopping "Qaud drive" or "Quad Trac" ? sorry for all the questions but i need to learn QUICK buying this weekend or next.
Jetjock16
Jetjock16 is offline
post #19 of 49 Old 09-22-2005, 11:29 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Selec-trac is the version with the 2x4 option. Quadra series are AWD with different setups in the differentials.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #20 of 49 Old 09-22-2005, 12:30 PM
HemiWay
If you want the really know the difference amongst the 3 drive systems check out this link from www.wkjeeps.com which has the most complete information about the WK.
http://www.wkjeeps.com/wk_4x4.htm
05 WK Hemi Midnight Blue
Former Jeeps 93 Ltd V8, 96 Ltd V8
Other Vehicle - Wife's Envoy XUV
HemiWay is offline
post #21 of 49 Old 09-22-2005, 12:38 PM
HemiWay
How about putting a sock in it for a change. Myself, and perhaps other WK owners here are getting tired of your underknowledged opinions about the vehicle. If you had ever driven the new electronic QDII system in snow on slippery pavement you wouldn't be making such unsubstantiated statements. But then again, that would mean you would be letting facts get in the way of your opinions.
HemiWay is offline
post #22 of 49 Old 09-22-2005, 01:54 PM
2Grand4s
So you're saying its an Inspector Gadget thingy !
Great ! Just one more reason I'm glad I avoided the 05 version.
And for the record, I've driven a jeep for 18 years, done a lot of my own repairs, and admit I'm not a mechanic. . . .BUT FORUMS, like this, are where one is Encouraged to express their opinion. If this was only for people who know all the answers, you'd be the only one posting.
2Grand4s is offline
post #23 of 49 Old 09-22-2005, 02:48 PM
HemiWay
...BUT FORUMS, like this, are where one is Encouraged to express their opinion. If this was only for people who know all the answers, you'd be the only one posting.
If an expressed opinion is based upon facts then it's an answer. If not, then it is a question not the answer.
HemiWay is offline
post #24 of 49 Old 03-02-2010, 12:57 PM
samiam2187
Originally Posted by BlaineWasHere View Post
V8 WJ= D44a rear axel
I6 WJ no tow pkg= D35c rear axel
I6 WJ w/tow pkg= D44a*
*sometimes they still have the D35c with this set up too... It can really go either way...
Correct on 2 examples. I have an I6 without the factory tow package and I have the D44a in the rear with 3.73 gears. It seems to be a bit rare, but they are out there.
samiam2187 is offline
post #25 of 49 Old 03-02-2010, 04:50 PM
Falkon
Wasn't the original question about WJ drive systems? Here is some great info...
Jeep Grand Cherokee WJ - WJ Four-Wheel Drive Systems
Falkon is offline
post #26 of 49 Old 10-15-2013, 11:51 AM
damon36
Wj
I just noticed a couple of things, ONLY in 2004 they offered a Quadra Trac 1 in the 2004 Laredo with the I6 and uses the NV147 transfer case.....weird as it says it only has 4 wheel drive high. No neutral nor low. NEVER have I seen one. What is it a button like the 2005 on up?
The next thing, this 11 th Grand Cherokee WJ I have is a I6 with the quadra Trac 2 and it has the NV-247 transfer case just like the quadra drive. So what type of transfer case oil should I use, and also on the front and rear diffs I am going with Redline 57914 75W140 GL5 Gear Oil as it already has the limited slip additive. Comments on transfer case oil?
damon36 is offline
post #27 of 49 Old 10-15-2013, 03:04 PM
daman02
QTII is when they had the low range option. As far as oil only use the mopar oil for the NV247 tc from dealer as it already has the proper amount of friction modifier in it. No one else offers it. DO NOT put anything else in it!!
'04 WJ 2.5" bb and 265/65-17 General Grabber AT2
daman02 is offline
post #28 of 49 Old 10-15-2013, 06:37 PM
AIRBORNE
Okay, so now after reading this thread and the clicking the link, I am confused. I have the 2000 WJ LTD, and it says my Quadra Drive was equipped with a "LO, part time"? Mine only has full time Hi and Lo. Was there another configuration?
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #29 of 49 Old 10-15-2013, 06:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I feel like ive hopped into my delorean and gone back in time. This thread was from 2005 lol.
Anywho, no, there was no other option. The lo in your "hi and lo" locks the drive shafts together making it a part-time use only setting.
~James
ezflip is offline
post #30 of 49 Old 10-15-2013, 06:50 PM
AIRBORNE
RGR. That makes sense.
AIRBORNE is offline
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 07:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
Quadra-TRAC vs. Quadra-DRIVE ptmeyer84 ZJ Grand Cherokee Forum 7 04-23-2007 05:56 PM
