Quadra-Trac II - JeepForum.com
post #1 of 7 Old 06-07-2013, 01:36 PM Thread Starter
merkdogg
Quadra-Trac II
Pops out going down hill and not on the gas..Will go back in on its own if i slow down...Shifter never moves ,does it all internally.It all started when the cable came off. Is there a adjustment for the cable or is something broke ?
merkdogg is offline
post #2 of 7 Old 06-09-2013, 12:10 AM
MuddyWJ
What pops out? What cable fell off? Is it the TC or trans shifter? Did you put the "cable" in the correct hole on the linkage? It would be the upper hole.
MuddyWJ is offline
post #3 of 7 Old 06-09-2013, 09:07 PM Thread Starter
merkdogg
The transfer case pops out into neutral . The transfer case cable came off and I put it back on. Since then it started the popin into neutral down hill stuff.
merkdogg is offline
post #4 of 7 Old 06-09-2013, 10:10 PM
MuddyWJ
There is a bracket that has two holes. Make sure it's in the top hole.
MuddyWJ is offline
post #5 of 7 Old 06-10-2013, 06:55 AM Thread Starter
merkdogg
Where is it located ? On the TC or the shifter ? The cable only came off from the TC and there no holes only a ball and socket kind of connection
merkdogg is offline
post #6 of 7 Old 06-10-2013, 12:13 PM
MuddyWJ
Under vehicle on top of TC. Can't miss it. Check to see if it's loose or off completely.
MuddyWJ is offline
post #7 of 7 Old 06-10-2013, 04:24 PM Thread Starter
merkdogg
Ok I will check it out . Thanks for all your input so far
merkdogg is offline
