Quadra Drive issue or normal for wj? - Page 2 - JeepForum.com
post #16 of 21 Old 01-29-2014, 05:07 PM Thread Starter
nickmills77
I usually run the psi the tire is rated for max pressure. My tires say 44psi max so I figured running 40 would be ok? Ive always filled my tires this way, and if im wrong I stand corrected but I thought my tire manufacturer would know what the best psi for tread pattern and type of tire not the lable on door jam.. like I said if im wrong ill change the pressure and start reading the factory label...
I added 2.5oz to the front and 4.0oz friction modifier to the rear as recommended on wjjeep.com
nickmills77 is offline
post #17 of 21 Old 01-29-2014, 06:10 PM
its-me-B
At my work we put 40 psi in tires regularly... no issues
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #18 of 21 Old 01-29-2014, 06:19 PM
Gander2
I had a 2004 Limited - and had the same lurking suspicion that the 4wd was not disengaged. I didn't have quite the "chirping in turns" that you experienced - but I never pushed hard in turns just because I was trying to be kind to the 4wd system. But the vehicle felt heavy in turns, and not "quite right". (I had a moderate amount of experience with Jeeps having owned a 96 Grand Cherokee and a 96 Cherokee) Front left CV joint went at 42k miles, then the right around 60k. Around town gas mileage was horrible - 10mpg - and I wasn't hot dogging. I could never figure out a way to determine if the 4wd wasn't engaged. Oh - and it was "factory used" vehicle - that came with no transmission fluid in it even though it was supposed to be factory certified - so I lost faith in it quickly.
I liked the vehicle but got rid of it at around 85k because I was sure a major 4wd repair was in my future and wanted to get max value for it (also it was uncomfortable to drive, the A pillar visibility was horrible, and the metallic paint job wasn't of the highest quality, and the gas mileage horrific). Loved it on the highway but just didn't love it enough.
Gander2 is offline
post #19 of 21 Old 01-29-2014, 06:51 PM
JeepNowski
My '04 QD limited does something similar as yours. When I'm on dry pavement and make a turn in either direction with the wheel turned all the way it feels like it grabs as it is turning. I changed my diff fluid and put in the proper amounts of friction modifier and it still does it. I doesn't affect my jeep in any way though....The 4wd kicks in when I feel like it should.....I've had my WJ's QD kick in more times in the last week than I've ever had it in the 6 months that I've owned it due to recent ice storms.. When my QD kicks in you can feel it, but it feels like it is almost instantly when my rear tires start to spin. There is no "few seconds of delay" before it kicks in.
Keep in mind, I'm probably not nearly as schooled in WJs as a lot of these folks in here so take all that with a grain of salt.
JeepNowski is offline
post #20 of 21 Old 01-29-2014, 07:07 PM Thread Starter
nickmills77
According to this video, I shouldn't get any front wheel power until I have lost traction in both rear wheels..
post #21 of 21 Old 01-29-2014, 07:22 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by nickmills77
Video Link: http://www.youtube.com/watch?v=0PmxnShlfZI According to this video, I shouldn't get any front wheel power until I have lost traction in both rear wheels..
Don't listen too much to videos. The fact is that if there is any difference in speed between the rear and front driveshaft it will start creating pressure and grab the front drive shaft. The pump is physically between the drive shafts. If both are spinning the same speed the pump rolls with them and no pressure is created. If one shaft is going faster than the other the two elements are going different speeds and pressure is created.
Its the same principal for the variloc's in the differentials.
86cj74.2L is offline
