Pulsing Vibration in Overdrive - JeepForum.com
post #1 of 3 Old 05-15-2011, 04:11 PM Thread Starter
UPJeepster
Wj Pulsing Vibration in Overdrive
First post here.
Just picked up a 1999 WJ a few months ago. The rig is all stock with a 4.0L and 42Re. On my last long trip I noticed a faint pulsing vibration when in Overdrive only. It mostly occurs when going up hills or accelerating. The vibration seemed to start after I replaced drag link ends, but is coming from the middle/rear end. Can't seem to pin down where the vibration is coming from and it seems to be getting worse. My first thought is transmission mounts, but not sure how to check those.
I've done a bunch of searching and found many threads on this type of problem, but the ones I could find were dealing with lifted WJ's and Wranglers.
Thanks in Advance
UPJeepster is offline
post #2 of 3 Old 05-17-2011, 06:38 PM Thread Starter
UPJeepster
Alright, so didn't get any replies on my vibration problem, but figured it out and thought I would post my solution since this seems like a pretty common problem.
Turns out a rubber isolator around an exhaust hanger slid out of place. The hanger was right next to the transmission pan. Pretty simple fix....just slid the rubber isolator back into the housing. Thought it was going to be something more serious since it ONLY happened in OD.
I posted some pics of the hanger I'm talking about in case you have this problem...hopefully it will clarify
post #3 of 3 Old 05-17-2011, 07:16 PM
thestig_wj
Just saw this thread and my first thought was exhaust before I opened it I'm having the same problem only mine the hanger is completely broke
thestig_wj is offline
42REradic overdrive... i think? AGDubyaJ WJ Grand Cherokee Forum 20 04-07-2012 02:42 AM
No overdrive MadDawg150 WJ Grand Cherokee Forum 7 04-18-2011 11:00 AM
PLEASE HELP!! jeep is going in and out of overdrive JerzeyBoyWJ WJ Grand Cherokee Forum 21 10-30-2010 01:00 PM
WJ overdrive problem Renegade WJ Grand Cherokee Forum 2 04-27-2010 02:45 PM
Brakes pulsing Bill08690 WJ Grand Cherokee Forum 2 04-21-2004 03:02 PM
