Pulling out shorthairs... Window problems - JeepForum.com
post #1 of 4 Old 01-03-2011, 05:49 PM Thread Starter
gunner_woody
Wj Pulling out shorthairs... Window problems
I have recently aquired a 2001 WJ larado with the 4.7 V-8. Both back windows do not roll up or down with the master switch or the rear switches. This is on BOTH rear windows. The front operate fine and when I try the master sitch for the rear, I can hear what sounds like a solinoid actuating in the door. Any help?
gunner_woody is offline
post #2 of 4 Old 01-03-2011, 05:55 PM
steveridesli
go on ebay and order a regulator for each door its like 40 bucks. Or 100 at advanced auto.
either way you can change em in 15 minutes with basically a phillips and vice grips..
i think theres videos or picture walk througghs somewhere even
4 inch RC-X + 2 inch BB
32 x 11.5 BFG MUDS
15x8 Soft 8's
Mudered Out
steveridesli is offline
post #3 of 4 Old 01-03-2011, 08:36 PM Thread Starter
gunner_woody
It just seems odd that both rear windows are out... that is why I am thinking there is another problem, I am going to do some testing tomorrow
post #4 of 4 Old 01-04-2011, 12:04 AM
lvum4x4
You need to take off the door panels and take a look ...my right rear window never worked so I finally got in there and found that the PO rigged up a PVC pipe to hold the window up because the plastic cable retainer broke (as so many of them do). I found a free fix but you can get replacement regulators for less than $100.00 if it comes to that. Check out my build thread for the free fix if you find that you have the same problem I did.
It only takes a couple of minutes to see what is going on, then you can work your way backwards from the door.
Hope that helps?
Kevin Bentley
Build:
http://www.jeepforum.com/forum/f197/bentley-project-wj-build-thread-870037
lvum4x4 is offline
Still pulling to the right after alignment...this is getting old. jeepguy0311 WJ Grand Cherokee Forum 25 10-29-2010 10:37 AM
2004 WJ pulling to the left (off-set ball joints) Steve_Block WJ Grand Cherokee Forum 3 08-07-2010 03:08 PM
Pulling a small trailer with the WJ- OD or no OD? kadetklapp WJ Grand Cherokee Forum 5 07-22-2010 08:59 AM
Pulling Out Dents? steveridesli WJ Grand Cherokee Forum 7 04-06-2010 08:57 PM
99 GC Power Window problems 99GrandC WJ Grand Cherokee Forum 8 05-06-2003 07:51 PM
