Pulley noise - JeepForum.com
post #1 of 23 Old 03-04-2014, 05:26 PM Thread Starter
TSGR
Pulley noise
Metal on metal noise coming from a pulley on my 4.7. I can't tell which one it is, I was wondering if any are common or prone to failure.
TSGR is offline
post #2 of 23 Old 03-04-2014, 05:40 PM
heitzman
Belt tensioner
heitzman is offline
post #3 of 23 Old 03-04-2014, 05:53 PM
shockracer
I would replace the idler pulley and tensioner pulley, maybe even the tensioner assembly. Check your belt well you're under there, it maybe time for one as well.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #4 of 23 Old 03-04-2014, 06:47 PM
heitzman
Remove your belt tensioner pulley and you will be able to tell if its bad.
heitzman is offline
post #5 of 23 Old 03-05-2014, 11:30 AM Thread Starter
TSGR
well i replaced the idler and tensioner pulley today, the noise is still there. I also bypassed the a/c compressor, that's not it either.
TSGR is offline
post #6 of 23 Old 03-05-2014, 11:32 AM
Double E
Double E's Avatar
Alternator is next... mine was replaced but not due to noise.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 23 Old 03-05-2014, 11:55 AM Thread Starter
TSGR
I'll just wait to have it checked out when I get it inspected. Done throwing parts at it, already wasted over $60 between the pulleys and the shorter belt to bypass the a/c.
TSGR is offline
post #8 of 23 Old 03-05-2014, 12:12 PM
soonerdg
2003 WJ
I'd get it checked out sooner rather than latter. There are only two pulleys left, alternator and water pump. If the pulley is making that kind of noise it's because the bearing is toast. It will fail rather quickly.
soonerdg is offline
post #9 of 23 Old 03-05-2014, 01:14 PM
heitzman
Take your belt off and start it up and see if it is still there, but don't leave it running to long. Get back with us.
heitzman is offline
post #10 of 23 Old 03-05-2014, 01:28 PM
shockracer
Take the belt off and rotate the accessories by hand, you should be able to feel a worn bearing.
post #11 of 23 Old 03-05-2014, 02:43 PM Thread Starter
TSGR
I turned the pulleys by hand and didn't feel or hear anything abnormal. It only makes noise at a certain rpm range, just above idle and upon deceleration, sometimes at idle (seems worse when it's really cold out.)
TSGR is offline
post #12 of 23 Old 03-05-2014, 02:59 PM Thread Starter
TSGR
Also started it without the belt and couldn't hear it
TSGR is offline
post #13 of 23 Old 03-05-2014, 03:00 PM
heitzman
timing chain tensioner? Have you started it with the belt off?
heitzman is offline
post #14 of 23 Old 03-05-2014, 03:12 PM Thread Starter
TSGR
Yes I started it without the belt and could not hear the noise. But like I said it's intermittent. The only thing I noticed is the ps pump pulley doesn't turn as freely as the others. Normal or no?
TSGR is offline
post #15 of 23 Old 03-05-2014, 04:09 PM
soonerdg
2003 WJ
Well depending on how bad the bearing is it may only make noise when the belt is on and it's under tension. I've always been able to pinpoint the bad pulley just by opening the hood and litening to the front of the motor. It's usually pretty obvious which pulley is grinding.
soonerdg is offline
