Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! - JeepForum.com
post #1 of 12 Old 02-01-2009, 09:40 PM Thread Starter
Soft 8
I started having problems with my 545-RFE a couple weeks ago. I started doing some homework on them and was pretty impressed. Long story short, I replaced my vehicle speed sensors which helped the shifting problem and eliminated the erractic shifts it had started to suffer from. But it still wasn't right, there was something just a little off.
After talking to the previous onwers (Family) Everyone thought the transmission fluid had been changed a while back but couldn't remember when exactly.
I had always heard that changing the fluid on a high mileage transmission was a bad idea, it would wash the varnish off of the clutches and ruin it in a short time. After doing more and more homework I found more and more contradicting information.
So off came the pan to see what I could find:
In all honesty I was expecting to a snap ring(s) or lots and lots of clutch material.
This is what I found in the bottom of the pan:
It was dirty, very dirty; but the fluid wasn't burnt.
Both filters were replaced (with Wix a Trans Filter Kit) which included the pressed in seal in the case of the transmission. I added fresh ATF+F and took it for a test drive and was really impressed with how much different it felt. No more flare up going in to 5th gear, the shifts were much more fim (Imagine that!). After taking it for a couple of test drives, I checked the fluid level one more time and corrected it as needed.
SO FAR, no leaks, no mis-shifts, no noise, SO FAR SO GOOD!
Let me know what you think of what I found in the pan!
Dont make me take my top off.
Soft 8 is offline
post #2 of 12 Old 02-02-2009, 05:51 AM
Turbonut
Probably hasn't been changed for a while, but looks like normal wear sediment on the pan and magnet.
Turbonut is offline
post #3 of 12 Old 02-02-2009, 02:37 PM
compcrasher86
you are a lucky man. If that is indeed the original fluid, you were roughly 5 tansmission fluid changes overdue! LOL glad you caught it when you did
Matt
compcrasher86 is offline
post #4 of 12 Old 02-02-2009, 02:53 PM
Pbux690
So what exactly were the steps that you took in changing the transmission fluid. Did you just drop the oil pan. Clean it, drain the old fluid(where is the plug in ur picture?), change both filters(theres two?), Add the trans fluid(How many quarts?), then reattach the oilpan cover? Thanks
3" IRO, Rear Endlinks, BD Shocks, 16x8 Soft 8's " BS
265/75/16 Mickey Thompson MTZ, K&N FIPK Performance Intake, Power Raid TBS, Dual Straight Pipe,
Thule RR, High Lift + Mount, Westin Brush Guard, PIAA 5200, Many interior accessories
Pbux690 is offline
post #5 of 12 Old 02-02-2009, 03:02 PM
windsors03cobra
I changed it in my 99 V8 Exploder @ 160k and it was original, not as much sludge but close. Noticed same much better shifts and performance overall, 15k miles since with nary a problem.
windsors03cobra is offline
post #6 of 12 Old 02-02-2009, 03:06 PM
99avant
You got it, except there is no drain plug. Just be careful when pulling the pan, that is when it all comes out.
The number of quarts depends on the model. I think its 6 for the 545fe
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #7 of 12 Old 02-02-2009, 03:11 PM
Pbux690
Thanks for the conformation I bought mine with 98xxx and now its got 124xxx i think its time to change. Where do you add the trans fluid. Is there a gap under the hood or what, also do you have to add any seals on the oil pan so it wont leak or is it just fine to bolt it back up??
Pbux690 is offline
post #8 of 12 Old 02-02-2009, 03:14 PM
allenjp
Pbux690: You may want to watch someone who has done it before first or it WILL get very messy
This is my JEEP. There are many like it but this one is mine...
1996 ZJ 318 Laredo Quadra Trac -SOLD (I'm gonna miss her!)
2002 WJ 4.7 Limited Quadra Drive (sharing it with wifey for now...)
allenjp is offline
post #9 of 12 Old 02-02-2009, 03:18 PM
Pbux690
Mess is the last thing im worried about. But yeah maybe observing or having someone help would be better off than just diving into it.
Pbux690 is offline
post #10 of 12 Old 02-02-2009, 03:41 PM
JrMechanic
It's an easy job. From experience, I've found that a plastic trash can lid (Convex one), upside down with drain holes poked into it works great for funneling it into a drain pan
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #11 of 12 Old 02-02-2009, 05:02 PM Thread Starter
Soft 8
I varified when I dropped the pan that it was the original fluid because it had the OEM gasket material. That and when I brought home the filters no one had seen that style before so... no one had been in there.
I have a 4.7L with a 545-RFE, This is also the same transmission behind the Hemis in the 1/2 ton Rams so they are gaining popularity in the aftermarket. Mine ended up using 8 quarts for just a fluid and filter change. There is no drain plug in the transmission pan. So... The tip about the trans can lid is a good idea. I wish I would have thought of that. I didn't realize the transmission pan was so big (I am used to the 727's) until I crawled under there with my catch pan... that was the same size as the transmission pan.
I picked up a set of WIX filters from Oreilys, I didn't care for the pan gasket that came with the WIX filters so I used the gasket from a Pioneer filter kit. The WIX kit gave me both filters and the seal that is needed to do the filter change.
Also this is a good reference on the process.
http://www.nagca.com/forum/archive/i...p/t-33521.html
You will have to copy and paste the links in to the browser to get the pictures to work but it is all there.
Soft 8 is offline
post #12 of 12 Old 02-02-2009, 05:10 PM
ZeJokee
I replaced my trans fluid in my 93 ZJ limited over the weekend. It has 197,000 miles on it. It had never been changed before. The pan was clean and the fluid was not burnt and very little slug. I was very surprised.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
Pulled 247 and trans fluid came out Granam73 ZJ Grand Cherokee Forum 7 03-05-2009 07:56 PM
Another Trans. Fluid Leak - HELP! (pics) Jayrod586 ZJ Grand Cherokee Forum 8 05-14-2008 04:02 PM
Took some pics of a little trail action! and found my future tires and wheels! PICS! Soft 8 ZJ Grand Cherokee Forum 18 11-20-2006 01:11 PM
Original Trans Fluid? JoiseyJeff ZJ Grand Cherokee Forum 1 01-02-2006 06:46 AM
Pics. Billet grill for under 10 bucks... Cool trick. Pics Derek33 ZJ Grand Cherokee Forum 22 02-21-2005 01:48 PM
