Progressive Coupler, CV Joint or what? - Page 2 - JeepForum.com
post #16 of 25 Old 06-08-2012, 05:36 PM
Laidback
Originally Posted by dvt View Post
roadcrew, are you speaking about the transfer case or the diffs? I already have correct fluid in TC but not sure about the diffs. I'm trying to suss out if I have vari-lock or not as I've read you need friction modifier. I just brushed down a rusty tag on the diffs back and front and both say 80w 90 on them. Do I need FM in there as well? Could the wrong fluid in the diffs be causing my binding in tight turns?
It usually says on the tags if you need FM...
Laidback
Laidback is offline
post #17 of 25 Old 06-09-2012, 03:40 AM Thread Starter
dvt
Roadcrew,
Don't suppose you could send the request for me for the build sheet. It won't let me complete.the request as I'm in the UK.
VIN is 1J8G8E8282Y119728.
I'll probably still need you tell me what diff I have!
dvt is offline
post #18 of 25 Old 06-09-2012, 02:54 PM
roadcrew
I can try. It takes a few days to get a response. I'll let you know what I find.
roadcrew is offline
post #19 of 25 Old 06-10-2012, 06:00 AM Thread Starter
dvt
Cheers bud
dvt is offline
post #20 of 25 Old 06-10-2012, 06:21 AM
01beachjeep
Look by your shifter. Does it say quadra trac or quadra drive?
01beachjeep is offline
post #21 of 25 Old 06-10-2012, 12:33 PM Thread Starter
dvt
Quadra Trac.
dvt is offline
post #22 of 25 Old 06-10-2012, 07:24 PM
01beachjeep
Quad tracs do not have vari loc axes and should not get FM.
post #23 of 25 Old 06-11-2012, 04:58 AM Thread Starter
dvt
Ok thanks for that.
dvt is offline
post #24 of 25 Old 06-11-2012, 05:51 AM
Laidback
I read somewhere on here that you could option for a rear vari-lok...Here - http://www.jeepforum.com/forum/f310/...l#post11898611
But as this thread is only regarding a problem at the front it's not relevant.
I think he's isolated it to the front axle and if it was the diff it would affect both right & left turns, wouldn't it? No, not necessarily I suppose.
Laidback
Laidback is offline
post #25 of 25 Old 06-11-2012, 02:39 PM
roadcrew
Hey dvt. I have your build sheet. Pm me your email and ill sent it a little later.
Nice jeep by the way and no fm needed in your open diffs.
roadcrew is offline
Replacing Progressive Coupler on a 247 mctwin2kman WJ Grand Cherokee Forum 3 02-20-2012 08:16 AM
Where is the best/cheapest place to buy a Progressive Coupler Brian321 WJ Grand Cherokee Forum 4 02-01-2012 10:29 AM
2000 WJ - Viscous or Progressive Coupling? DigitalPest WJ Grand Cherokee Forum 3 10-27-2011 04:42 PM
thrust washer for 247 progressive coupling - quick help please jurgovan WJ Grand Cherokee Forum 13 09-06-2011 08:01 PM
Transfer case question/Viscous Coupler ?? jmastffp WJ Grand Cherokee Forum 2 05-27-2010 03:21 PM
