problem removing a 2000 jeep grand cherokee serpentine tensioner. - JeepForum.com
post #1 of 18 Old 01-15-2012, 09:13 AM Thread Starter
TommySA
I am having a real problem removing a 2000 jeep grand cherokee serpentine tensioner. The only bolt I can see is on the front and it looks like a star bit.
I tried a 30 which was too small and a 40 was too big. It is also not an Allen wrench
Could this be just a cap over the real bolt that holds the Tensioner.
If it is a cap can it just be removed by putting a screwdriver under the lip of this bolt and tapping it off with a hammer.
I went to the dealership and the mechanics told me they use a regular socket to remove the tensionar.
I do have the new tensioner and there is a hole all the way through where this bolt is located (on The Front)
Is it possible that someone installed the wrong bolt.
I just don't want to do something that will damage anything.
The vehicle is a 2000 Jeep Grand Cherokee Laredo - 6 cylinder with AC
Thanks in Advance
tombeavan@live.com
TommySA is offline
post #2 of 18 Old 01-15-2012, 09:17 AM
Ravie
No, the tensioner as far as I know is integral to the alternator mount which has 4 bolts on it. At the very least I'd take that whole thing off (which is easy, two bolts for the alternator and 4 bolts for the bracket) to get a better look-see.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #3 of 18 Old 01-15-2012, 10:02 AM
Cirruslydakota
Taking off the tensioner is a real PITA if you're doing it while on the vehicle with the limited room and all. Remove your alternator and remove the entire bracket assembly and put it in a vice. This will make it much easier for you and if its the original one like mine then you'll need to use a pick and clean out all the crap in the bolt head so your socket gets a good bite or risk stripping it out. I think its a T-35 but don't quote me on that. I ended up tapping the bolt with a hammer a few times to help break it loose and when I reassembled it I put some anti-seize on the threads for the future.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #4 of 18 Old 01-15-2012, 10:22 AM
nickblack
It is a t35 and only Jeep would do an asinine thing like putting a torx bolt in a place like that. I just don't get it, along with the torx bolt on the lower control arm. Utterly ridiculous in every way. They must have got a good deal on them. Lube it up and don't strip it. I replaced mine with a regular bolt a long time ago.
nickblack is offline
post #5 of 18 Old 01-15-2012, 11:02 AM Thread Starter
TommySA
Any Idea where I can Purchase The T35?
I tried the local auto stores including Napa and sears
Thanks in Advance
TommySA is offline
post #6 of 18 Old 01-15-2012, 11:10 AM
StrokedWJ
StrokedWJ's Avatar
I went through this recently. I broke 2 of the torx bits trying to get it off the jeep. Tried PB Blaster, etc but it didn't help. I ended up removing the entire tensioner bracket. Once out, I was able to grab the sides of the torx bolt with some vise grips and spin it out. Total PITA!
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #7 of 18 Old 01-15-2012, 11:32 AM Thread Starter
TommySA
how did you remove it if you could not remove the torx bolt?
The edges of the torx head are very thin
I think I might have to grind the Tensioner below the head to grab hold of it with vise grips
thanks
TommySA is offline
post #8 of 18 Old 01-15-2012, 11:56 AM
StrokedWJ
StrokedWJ's Avatar
Believe me I know, lol. The pliers barely had anything to hold onto but their teeth dug in enough to get the job done. My next plan of attack was to weld a standard socket to the end of the torx head. Once it broke free, the rest of the bolt turned out pretty easy.
post #9 of 18 Old 02-25-2012, 07:38 AM
cifer6425
I am having this problem as well. To complicate things I live in Turkey and its not like I can run down to Auto parts store for what ever I may need. I think once my tensioner assembly arrives, I may just replace the pulley.
cifer6425 is offline
post #10 of 18 Old 02-26-2012, 09:03 AM Thread Starter
TommySA
I did finally get the old pulley off by grinding grooves into the the pulley and chiseling using the largest screwdriver that I purchased from home depot and hitting the head of the screwdriver with a hammer. The grinder attachment I also purchased from Home Depot. It was a 3 Inch grinder disk that is a cutoff wheel for steel, which comes in a packet of 5. You will need the attachment that you assemble together that you put the cut off wheel into. I also purchased a 12" Drill extension and put that into the drill. I also had to remove the free spinning pulley to the right and slightly above to allow better access. Most of the pulley is cast and will break apart. I did this until I was able to grab the bolt with a pair of channel locks. I replaced the torx bolt with a hex head bolt and put a fender washer under the head. The torx bolt head has a wider head then the bolt and covers the hole of the pulley, this is why you need a fender washer.
The hex bolt is what should have been there to start with. My wasn't that fun, It was a real pain in the you know what.
One suggestion though, cover the openings of the alternator so that steel dust from the grinding will not get inside the alternator or remove the alternator altogether.
Hope this post helps the next poor soul having this same problem.
TommySA is offline
post #11 of 18 Old 01-12-2014, 01:52 PM
fayceoff
fayceoff's Avatar
Just did this day before yesterday on my 99. I removed the alternator, then removed the alternator bracket, which the tensioner arm is attached to. The pulley bolt is a T40 on the back side of the pulley and mine came out fairly easily, but I stood on it and used an impact driver... Only took me about 30 minutes.
fayceoff is offline
post #12 of 18 Old 04-28-2014, 10:56 PM
mkosobucki
Same problem with removing tensioner puley
Guys, I cat even access this T35, the fan shard is on my way. DO I have to remove radiator and fan shard first??
mkosobucki is offline
post #13 of 18 Old 04-29-2014, 09:28 AM
fayceoff
fayceoff's Avatar
No. See my post just above yours.
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
post #14 of 18 Old 04-29-2014, 08:37 PM
jeepyard
It's actually a T-40. I just changed the pulley on my 2000 and I had the whole bracket off anyway because the engine was out of it so decided to go ahead and replace the pulley before I put it back on the engine. It was hard to get loose even in the vise. I ruined 2 T-40 bits getting the bolt out. One twisted off completely and the other one almost twisted off. I tapped it with a hammer and chisel a couple of times and it came loose finally. Shouldn't be such a job just to replace a pulley!!!
jeepyard is offline
post #15 of 18 Old 04-30-2014, 11:36 AM
fayceoff
fayceoff's Avatar
So... Its a T40, and the best way to do it is to remove the alternator and its bracket....? Huh! Who knew?
fayceoff is offline
Trailer tow socket problem WJ Grand Cherokee 2000 marmotte WJ Grand Cherokee Forum 4 10-16-2011 09:35 AM
2000 Grand Cherokee 3.1 drive belt/tensioner slacker-ray WJ Grand Cherokee Forum 15 11-14-2010 10:32 PM
2000 Jeep Grand Cherokee Laredo Select trac I 6 Battery Cable Terminal Problem chesapeake WJ Grand Cherokee Forum 1 11-06-2010 06:27 AM
2000 Grand Cherokee Shifting problem mbolena WJ Grand Cherokee Forum 2 05-03-2010 07:23 AM
2000 Grand Cherokee seem to have a problem with the Tranny. WopHunter WJ Grand Cherokee Forum 1 02-03-2004 07:20 PM
