Probably shouldnt be dangling? - JeepForum.com
post #1 of 9 Old 11-12-2013, 10:21 PM Thread Starter
MichiganDuck
So, i'm pretty sure it's the fuel filter/pump/something behind the driver side rear tire.. used to be a metal box there, but i noticed today that the metal was gone and there was some sort of hose and cylinder partially dangling.. what are my options to fix this, and what is it?
MichiganDuck is offline
post #2 of 9 Old 11-12-2013, 10:27 PM
mycreativename
What year WJ? I ask because the vacuum something or other got moved back there after 2003 I believe.
A picture would help here a ton.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 9 Old 11-12-2013, 10:55 PM
rdkendrick
2003 WJ
The vacuum canister, LDP, and various hose are under the rear, driver's side wheel. It's the cause of many vacuum codes put out.
Sent from my iPad using my fingers
rdkendrick is offline
post #4 of 9 Old 11-13-2013, 01:57 AM Thread Starter
MichiganDuck
It's an 04 Laredo. How do i fix this? I'll see what i can do about pics in the morning. Seems like the rear bumper might have to come off to do anything.
post #5 of 9 Old 11-13-2013, 01:32 PM
cubalz
I thought that the canister was on the passenger side on that year. I could be wrong.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #6 of 9 Old 11-13-2013, 02:42 PM
rdkendrick
2003 WJ
I took the tire off and took out the wheel well. Taking the bumper off would probably help, as it's a real PITA place to get to.
post #7 of 9 Old 11-14-2013, 09:04 AM Thread Starter
MichiganDuck
What did you replace the box/shield that was there with? Any write-ups on this? I dont even know what to search..
post #8 of 9 Old 11-14-2013, 09:08 AM
ChrisHager
Administrator
ChrisHager's Avatar
You could just relocate it: http://www.jeepforum.com/forum/f197/...l#post10111574
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #9 of 9 Old 11-14-2013, 09:19 AM
rdkendrick
2003 WJ
I just had to get in there to fix my vacuum hoses, as I was getting a vacuum leak code.
