Power Window Module? - JeepForum.com
post #1 of 16 Old 08-04-2010, 11:07 AM Thread Starter
mreilly
Hello,
I worked for G.M. most all of my life so I'm still temporarily ignorant of Jeep things.
My daughter's fiance took this 2000 Grand Cherokee to Midas [of all places] to have the inoperative power windows looked at. The cost was $80.00 to tell him it needed a power window module which is supposed to be located inside the driver's door. I've been looking all over online for such a module and come up empty. Could they possibly mean a body module which would be located elsewhere? Any help would be extremely appreciated!
T'care,
Mike
mreilly is offline
post #2 of 16 Old 08-04-2010, 01:37 PM
WJeff
It probably the regulator. This is a common failure. It's a cable system and the plastic anchor for the cable breaks off. Take a look here: RockAuto Parts Catalog
WJeff
01 GC Ltd 4.7L
WJeff is offline
post #3 of 16 Old 08-04-2010, 01:40 PM
WJeff
The link I pasted was to the part but I see it just posted for the whole catalog. Go under Jeep and when you select year, model and engine - look under body-interior
WJeff
01 GC Ltd 4.7L
WJeff is offline
post #4 of 16 Old 08-04-2010, 01:48 PM
1AAdam
does he push the button and absolutely nothing happens or does it make clicking or grinding noises? the regulators are very common problems on these cars! i have changed one on my 01 and prob will change one on my 00 too. we carry them also and they have a lifetime warranty!
Jeep Grand Cherokee Window Regulator at 1AAuto.com
1AAdam is offline
post #5 of 16 Old 08-04-2010, 02:00 PM Thread Starter
mreilly
No there is no mechanical movement at all. It's definitely electrical and has been only working on and off for the last couple months; first one window, then another. Now it's just dead all the time. They told him it has power going into the module but nothing coming out.
Thanks,
Mike
mreilly is offline
post #6 of 16 Old 08-04-2010, 06:30 PM Thread Starter
mreilly
P.S. They were also told that the "module" is not available in the aftermarket; dealer only [400.00!]. Also, that there is a waiting list for them at the dealer as they fail so often, keeping them in stock is a problem. Does any of this ring true to you folks?
Thanks,
Mike
mreilly is offline
post #7 of 16 Old 08-04-2010, 10:16 PM
JS97ZJ
Do a search for power window switch at this site or go to your nearest JY
http://www.car-part.com/
Prices start at around 40-70.
JS97ZJ is offline
post #8 of 16 Old 08-04-2010, 11:18 PM
mverne
If it's the window motor, they are attached to the regulator and I believe must be changed as a whole...
I got mine here...
AM Autoparts - After Market Auto Parts - Headlights, Mirrors, and More
Haven't had any problems with it for the last two years, and it was a real good price.
mverne is offline
post #9 of 16 Old 08-05-2010, 09:07 AM Thread Starter
mreilly
Thanks to all of you for you help and input. Thanks also to mverne for putting me onto AM Autoparts. They had the exact switch we need for 65.00. Sure beats 300.00 to 400.00 at the dealer. We are happy campers!
Awesome forum,
Mike
mreilly is offline
post #10 of 16 Old 09-20-2010, 11:58 AM
mjw22
Sorry to hijack your thread mreilly.. trying to avoid starting a new topic! Would this fix help a driver's window that is very slow to roll down but rolls up just fine? Back window doesn't roll down at all, so I'm assuming this will take care of that too?
Originally Posted by Son-of-Beast View Post
- Nice interior - because surviving a zombie apocalypse doesn't have to be uncomfortable
♦ Lady Jeeper ♦
1999 4.7L WJ Limited || 1997 4.0L TJ Sahara || 1998 2.5L TJ SE || 1994 5.2L ZJ || 1989 2.5L YJ
mjw22 is offline
post #11 of 16 Old 09-21-2010, 08:40 AM Thread Starter
mreilly
mjw22,
That's OK. Happy to help if I can.
The thing about window switches is that they either complete the connection or they don't. That's to say, they work or they don't. Your rear window problem could well be a switch problem or a motor. You can check that out with a 12 volt test light.
As long as your front window works, although slowly, the switch out of the equation completely. The switch portion to that window is fine. If it's at least trying to go up and down, the switch has done it's job. For that problem I would look at a weak and failing motor or a binding regulator. Many of these have to be purchased as a unit and not sepatately. Check out AM Autoparts.com. Their prices are usually very hard to beat anywhere.
Good luck,
Mike
mreilly is offline
post #12 of 16 Old 01-28-2012, 12:27 PM
Wayno312
Hey mreilly, have been having the exact problem with my 06 GC. Did you replace the actual switch or the module thing that's inside the door?
Wayno312 is offline
post #13 of 16 Old 01-29-2012, 07:27 AM Thread Starter
mreilly
Hi Wayno312,
Well, this Jeep was a 2000 and yours is a 2006. Could be a lot of things different in 6 years. In ours, the word switch and module are one in the same. The one at the driver's door is referred to as the master switch/module. [It's still just the control assembly with all the buttons]. The 2000 had no other module inside the door.
In the end, our problem eventually turned out to be a broken wire in the loom/harness between the body and the driver's door. It broke from years of bending back and forth opening and closing that door in -20 degrees to +100 degree weather.
Bestalucktoyou,
Mike
mreilly is offline
post #14 of 16 Old 01-29-2012, 07:39 AM Thread Starter
mreilly
One more thing I should add. The module we got from AM Autoparts was the wrong one. It was listed for the Grand Cherokee, but was actually for the old style regular Cherokee. We ended up buying a used correct one online [turned out to be a good one too]. Now we have a spare whenever needed.
I contacted AM autoparts and they were really good about it and promised to fix their catalog right away. However, that also meant they did not sell the one for the GC; hence we had to get the used one. That was back in September of 2010 so they may offer the GC module by now.
T'care,
Mike
P.S. Just checked with them. Although their catalog is now correct, they still don't offer the GC module/switch.
P.S.S. We also bought an in-tank fuel pump module from AM last year for this GC. Great price; great part. Still working fine.
mreilly is offline
post #15 of 16 Old 01-29-2012, 10:46 AM
Wayno312
Thanks Mike.
I would imagine a lot of things changed in those years. My 06 has a box inside the door that plugs into the wiring harness which I thought was considered the module, but I could be wrong.
I was hoping my issue was a broken wire but I have not been able to find any. I'm going to fish around AM autoparts.
Thanks for your help!
Wayne
Wayno312 is offline
Window door module crumpy ZJ Grand Cherokee Forum 2 08-24-2009 01:45 PM
Drivers Door Window/lock module not working twisted_ed ZJ Grand Cherokee Forum 6 05-07-2009 09:44 AM
Anyone ever tried one of these? power module d-raw ZJ Grand Cherokee Forum 3 01-21-2009 07:04 PM
Drivers side window module on 2000 GC not functioning blackstripes ZJ Grand Cherokee Forum 1 09-02-2006 06:21 PM
radiator fan power module. bud84ro ZJ Grand Cherokee Forum 2 10-26-2004 06:47 PM
