Power Window Fuse Location? - JeepForum.com
post #1 of 25 Old 06-08-2011, 05:59 PM Thread Starter
HondaPeople
Hey all,
I just did a forum search and was unable to locate the power window fuse location. All of my power windows stopped working. Any ideas? Thank you!
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline
post #2 of 25 Old 06-08-2011, 06:34 PM
4Tom
Under your hood beside battery is power distribution panel fuse number 12
50amp see photo attached.
http://www.wjjeeps.com/fuses.htm if you need more information
Best of luck !
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 25 Old 06-08-2011, 06:57 PM Thread Starter
HondaPeople
Thank you sooooo much! Unfortunately, doesn't seem to be a fuse problem... not sure what it could be?
post #4 of 25 Old 06-08-2011, 07:10 PM
4Tom
Ensure battery connections are good and tight.
It is know for the earth wire to break in wiring harness going into the doors.
Most likely drivers door.
Pull back the rubber cover and check for broken wires.
WJ 2001 3.1TD
Tom
4Tom is offline
post #5 of 25 Old 11-17-2013, 11:03 AM
jplemmons30
windows and locks
I have an 04 jeep grand Cherokee the other day the power locks stopped work and the windows did at the same time. Any ideas
jplemmons30 is offline
post #6 of 25 Old 11-17-2013, 11:33 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Most of the time these problems are caused by a broken wire in the rubber boot between the door and the body. Pull the boot back and you will probably find your problem.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #7 of 25 Old 11-23-2013, 03:41 PM
moparJR
Guest
Posts: n/a
window problem
I have an 04 just fixed exact problem. Inside the door boot big black wire broke in 2. Heat shrink connector and its fixed.
post #8 of 25 Old 04-02-2014, 04:36 PM
Girth2k1
On my 2004 the wire was Orange with a white stripe. But problem has been repaired
Thanks everybody
Girth2k1 is offline
post #9 of 25 Old 05-09-2014, 10:04 AM
smgracy
I have a 2004 Jeep Grand Cherokee with the same problem. Checked the wiring, had a broken wire, fixed the wire. Battery connection was loose, fixed that. Checked fuses, nothing was blown. What do I do now? Really do not want to have to spend the money taking it to a dealer. Any help would be appreciated.
smgracy is offline
post #10 of 25 Old 06-07-2014, 04:10 PM
kfitzwphd
Wj Thanks!
Broken Black wire on passenger door, soldered new piece in, Pass side window and door locks back on.
kfitzwphd is offline
post #11 of 25 Old 07-09-2014, 02:10 PM
litlbug23
2006 WJ
Windows not working
Hello I seem to be having the same issues! I had the driver's side window switch replace because my windows weren't working on all four doors. The power locks and mirrors still worked. I could not get the passenger window up and the window lock was off. The only thing I do hear when I'm driving is what seems to be a "clicking" sound coming from the drivers side either door or under the steering wheel perhaps? I'm not really sure. Firestone said they looked at the fuse and it was ok. but it's happening again. After I hear this clicking noise the windows then work again so it's not the switch. Does anyone have any ideas??
I have a 2006 Jeep grand cherokee laredo.
Thank you!!!
litlbug23 is offline
post #12 of 25 Old 07-13-2014, 02:21 PM
Pro69Camaro
My wife complained to me of the power windows not working on her 2002 WJ, so I confirmed the power windows didn't work, and neither did the power mirrors. Hoping for the easy fix, I checked the fuse, but no dice, it was fine. I pulled back the boot between the body and driver-side door as suggested above, and sure enough, found the thicker black wire was completely split. I stripped a little off each broken end, then crimped on an electrical connector, and we're back in business.
Pro69Camaro is offline
post #13 of 25 Old 07-14-2014, 05:42 PM
kfitzwphd
I posted about my passenger side Black wire breaking on June 7, 2014. Well....My windows stopped working and the locks stopped on the driver side. I pulled back the boot and sure enough the Black wire was broken. This one had a wrinkle; The thick orange wire with a stripe (forget color) was also broken! I fixed this...but a warning; this wire is hot even with key off (my strippers got nailed, luckily they were shielded); be careful (like I wasn't at first). Also, a small wire was broken too. I fixed them all and everything is back to normal. I recommend disconnecting battery if you work on any of these wires other than the black (which is apparently the ground). Kevin
post #14 of 25 Old 08-04-2014, 05:43 PM
commanderson
You guys are amazing - mine are broken too (black wires and the orange/blue one) . The boot seems to be a pain in the ***, did you take it off to fix? If so, how?
Thanks in advance. (06' Commander)
commanderson is offline
post #15 of 25 Old 10-23-2014, 07:37 PM
jyduffy
I have similar problems but more confusing......
Driver side windows and power mirror are working, Passenger side are not
All fuses are intact. Wiring inside boot appears good although black was previously repaired.
I will 're-repair' black wire tomorrow but are there any other ideas as well?
Thanks in advance for any help any of you can give
2003 Grand Cherokee Laredo
jyduffy is offline
Power window repair dinovass WJ Grand Cherokee Forum 22 12-12-2015 10:28 AM
'04 Power window issue vwo4l WJ Grand Cherokee Forum 3 06-24-2015 03:41 PM
Yet another power window question jclay WJ Grand Cherokee Forum 6 03-08-2011 09:55 PM
Power Window Problem W2001J WJ Grand Cherokee Forum 9 02-14-2011 05:20 AM
No Power to Stereo - Checked Fuse 30 - OK jamesh02 WJ Grand Cherokee Forum 4 11-10-2010 03:58 PM
