Power steering loss - JeepForum.com
post #1 of 9 Old 01-02-2011, 09:35 PM Thread Starter
99_WJ_Laredo
Power steering loss
So....my power steering has been leaking which i thought was due to a bad high pressure hose. I replaced the hose yesterday which slowed the leak down but its still leaking from someplace.
I was driving the 99 Grand Cherokee today and all of a sudden, my power steering goes out. I check the fluid and it is full. No explosions, no smell, just loss of power steering.
Any help please? I need to drive this thing tomorrow and no power steering is dangerous on these icy roads...
(I was getting frothy fluid so i have bled the system which didnt fix the problem)
99_WJ_Laredo is offline
post #2 of 9 Old 01-02-2011, 11:44 PM Thread Starter
99_WJ_Laredo
Is there a way to test the power steering pump before i buy another one?
post #3 of 9 Old 01-03-2011, 08:28 AM
narnwv
narnwv's Avatar
My fluid was frothy when I changed my high pressure hose. Someone had put ATF in there, 'cause it was super red.
After the hose change, I took a hand pump and pulled out all the fluid in the reservoir into an old container, and then refilled with Valvoline PS fluid (meets Mopar spec). I repeated this process until all my fluid wasn't red at all.
Your fluid might not be red, but this procedure might help, as it'll only cost you 2 quarts of fluid.
~Aaron
narnwv is offline
post #4 of 9 Old 01-03-2011, 09:56 AM Thread Starter
99_WJ_Laredo
I didnt know about having to use special power steering fluid. So i used stuff off the shelf. Now that i flushed the system with the cheap stuff, do you think it ruined my power steering pump? Or do you think that if i drain and refill with the proper stuff, it will start working again?
post #5 of 9 Old 01-03-2011, 12:13 PM
Crewdude007
It's not really that special. Just as long as you use PS fluid that meets Mopar MS5931 specs. It should say on the bottle if it meets these specs.
Currently Jeepless
2001 XJ - SOLD
2000 WJ - SOLD
Crewdude007 is offline
post #6 of 9 Old 01-03-2011, 01:38 PM
narnwv
narnwv's Avatar
This is correct. Valvoline is one of the few that actually say this on the bottle. I run all Valvoline oils anyway (except Mobil 1 in the rear diff) so I jumped at getting the Valvoline.
~Aaron
narnwv is offline
post #7 of 9 Old 01-03-2011, 06:18 PM
nickblack
The reason ur fluid was frothy was because you introduced air into the system when you removed the HP hose. It had nothing to do with the ATF-4, although that is not the correct fluid.
nickblack is offline
post #8 of 9 Old 01-03-2011, 06:20 PM
narnwv
narnwv's Avatar
I am aware on both points, I was just explaining my process to him.
I didn't know it was even red until I pulled the old hose. I was just glad I had 2 quarts of the right stuff handy.
~Aaron
narnwv is offline
post #9 of 9 Old 01-04-2011, 11:20 AM Thread Starter
99_WJ_Laredo
**UPDATE**
So i ended up going to the junkyard and getting a power steering pump with the pulley and reservoir still attached. Came home, drained the system, put the new (used) pump assembly on and flushed it again. YAY! I have power steering again! And no frothy / foamy fluid. Thanks for all your help guys!
I guess that during the time i had a leak, the pump sucked too much air and decided to take a poop on me. Also, i went to oreileys and looked for fluid that met mopar spec. To my surprise, the O'Reily's house brand of power steering fluid met the specs of the mopar stuff. And its like $12/gallon! Good stuff
Loss of power under acceleration. :( SplitNail WJ Grand Cherokee Forum 107 01-24-2013 09:15 PM
Loss of power @ low revs Mr_Grumpy WJ Grand Cherokee Forum 6 09-30-2010 03:06 PM
Loss of power steering at idle? RNCC4X4 WJ Grand Cherokee Forum 4 08-31-2010 08:49 PM
Random no start with total power loss dougy147 WJ Grand Cherokee Forum 2 07-27-2010 06:04 PM
2000 4.7 V8 Laredo power loss XSNRGY WJ Grand Cherokee Forum 6 04-10-2010 02:33 AM
