Power steering intermittent - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Power steering intermittent
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 06-24-2012, 04:53 PM   #1
Lysdexic
I'm experiencing some odd symptoms - now and then after driving for a while, if I come to a stop and then try to turn the wheel it feels like the power steering is gone - as soon as I start to move it works again, this comes and goes.
Anybody else have this happen?
If it's easy to get to it's probably not worth seeing.
Lysdexic is offline   Reply With Quote
Unread 06-24-2012, 05:46 PM   #2
coopdc78
Yes I too have the same problem.. although I'm in the middle of the engine rebuild..I'm putting a new pump on cause I'm sure that's what it is..plus its pretty cheap
1995 ZJ, limited, 5.2, 242 t-case.3in skyjacket..2inbb.. sold
2000 camaro ss/slp in garage
2004 overland stock
Why do we measure our engines in liters when we pump gallons into them
coopdc78 is offline   Reply With Quote
Unread 06-24-2012, 05:53 PM   #3
Larryftmfw
Mine was doing that, new ps pump fixed it.
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote
Unread 06-24-2012, 08:38 PM   #4
JForest2
Does it do it in both directions? If so it's most likely your pump.. If it only does it in one direction its your steering box..
James
JForest2 is offline   Reply With Quote
Unread 06-24-2012, 09:30 PM   #5
Lysdexic
Both directions. Ordering a new pump right away. AC/Delco reman from Rock Auto $121.79
Unread 06-25-2012, 03:45 AM   #6
Larryftmfw
How hard is it to put in a new steering box? Also are there supposed to be nuts on these bolts? It looks wet cause I was doing the ps pump while I took the picture.
