power steering fluid - JeepForum.com
post #1 of 6 Old 01-13-2014, 01:21 AM Thread Starter
pentastarguy
2015 JK Wrangler
anyone know the part number for the proper fluid for an 04 4.7 limited? parts guy said there was 2 fluids available. wasn't really filled with confidence with this guy. also any aftermarket fluid that would be useable? tks all.
pentastarguy is offline
post #2 of 6 Old 01-13-2014, 01:39 AM
nmay
nmay is offline
post #3 of 6 Old 01-13-2014, 06:43 AM
pdpunome
I have a new unopened 1qt available which I am selling on ebay or on here, but it is the same part # for both 4.0 and 4.7's. Myn is Mopar. PM me if your interested.
2000 4.0 Selec Trac
pdpunome is offline
post #4 of 6 Old 01-13-2014, 08:37 AM
Jeeples
Jeeples's Avatar
Go to the parts store and look for the Valvoline PS fluid in the white bottle, it says right on the back that it meets Mopar fluid spec MS5931, if you have an Advance nearby their house branded fluid is GTG as well. O'Reilly sells the MasterPro brand of fluid that meets the correct specs also. Any of these options should only run you $5-$6 a quart, vs. whatever inflated price the dealer is wanting to charge you.
There's plenty of threads on here discussing the viability of the options I just mentioned. Do a little searching.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 6 Old 01-13-2014, 10:32 AM
KayCeeJeep
What he said, excellent post. I have used both the Valvoline and the MasterPro he mentioned from O'Reilly's they are fairly affordable and easy to find. The key is to look for "meets or exceeds MS5931" on the bottle. Lots of generic multi purpose products will use vague language like "suitable for" "replacement for" Chrysler yada yada yada. Nope!
STOCK WJ WARRIOR
2004 4.0 Laredo Selec-Trac at 140k
General Grabber AT2's
KayCeeJeep is offline
post #6 of 6 Old 01-13-2014, 12:39 PM Thread Starter
pentastarguy
2015 JK Wrangler
tks all.
