Power to the rear power outlet ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Power to the rear power outlet ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOfficial Chassis Saver Rust Preventive Truck & Auto UnFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-12-2014, 06:01 AM   #1
jeepster2000
The rear power outlet on my Overland is not working ?
I have checked all the fuses under the dash,but they all seem ok,is there a "hidden" fuse box that would have the relevant fuses for the rear power outlet please ?
2004 OVERLAND 4.7 HO V8 with quadradrive
jeepster2000 is offline   Reply With Quote
Unread 04-12-2014, 06:34 AM   #2
texlurch
http://www.wjjeeps.com/misc/power_dist_ctr_02.jpg
Item 27. If that is good check the connection behind the panel in the rear.
This is the fuse box under the hood, next to the battery.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline   Reply With Quote
Unread 04-12-2014, 07:39 AM   #3
jeepster2000
Excellent thank-you for that...
I'll have a check on that when I get back home .....
Thanks again........
Unread 04-13-2014, 06:48 AM   #4
jeepster2000
That solved the problem :-)
Thank-you,if only I could now find a link on how to replace my front door straps my work is complete ......
Any body help with that one please ? :-(
