power-to-manual seat swap - JeepForum.com
post #1 of 7 Old 09-29-2013, 09:58 PM Thread Starter
printC8893
In case I can't find a power seat at the junkyard, would a 2000 manual seat bolt in where I remove the 2000 power seat?
printC8893 is offline
post #2 of 7 Old 09-29-2013, 10:22 PM
rcwj04
.....yes.....
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #3 of 7 Old 09-30-2013, 08:32 AM Thread Starter
printC8893
Thanks for taking the time to answer. Sorry if I didn't make myself very clear. I'm not trying to weld anything. I'm trying to expand my chances of getting a cheap seat by looking at junkyards for either a power or non-power driver seat for my 2000 Grand Cherokee. Right now it's a power seat which has a frame with mutiple breaks in it. If I can't find a power seat but do find a non-power seat (from a 1999 to 2004 Grand Cherokee) I was wondering if that would work. In other words, 1) is the bolt pattern the same and, 2) would any other modifications need to be made to swap to a non-power seat (other than removing the old electrical stuff)?
The top of your response said just "yes". So I can unbolt the power seat with the four floorpan bolts and replace it with a non-power seat, and the holes will line up and the seat will work manually just like a manual seat is supposed to? Thanks again. This forum is fantastic.
post #4 of 7 Old 09-30-2013, 08:43 AM
rcwj04
If you take a non power seat from a junk yard take the track with it. Not 100% positive but I'm pretty sure the tracks are different. The only difference between the actual seats it's the power motor
rcwj04 is offline
post #5 of 7 Old 09-30-2013, 08:52 AM
MIKEJONES
It will bolt right in and work fine.
Build Thread - WJ on 35s
http://www.jeepforum.com/forum/f197/wj-35s-custom-built-bumpers-roof-rack-sliders-etc-1564833/#post15816151
MIKEJONES is offline
post #6 of 7 Old 09-30-2013, 09:42 AM Thread Starter
printC8893
Thank you rcwj04 and Mike Jones. This helps a ton.
post #7 of 7 Old 09-30-2013, 09:51 AM
rcwj04
Yeah ignore what I said about the tracks. I was thinking of converting a seat to power. The seat will just bolt in
rcwj04 is offline
