Power to all doors and windows cut off when driver door is open - JeepForum.com
post #1 of 6 Old 09-01-2011, 05:00 PM Thread Starter
Bubba3200
02 Overland....when I open the driver door all the power to all doors and windows cuts out. So does the courtesy light on the driver door. All other lights on all other doors stay on. Close the driver door everything is fine. I have pulled back the rubber boot on the driver door where the wires go from the body to the door and they look good.
Anyone have any suggestions?
Where the wires go from the door to the body how can I access this? Take the pannel off down by the fuse pannel by where my left foot rests?
Bubba3200 is offline
post #2 of 6 Old 09-01-2011, 05:19 PM
4Tom
Only takes a few mins to double check
Unclip boot & Carefully inspect the black and orange/White cables inside the drivers door boot.
These are the two thickest cables.
Look for damage or bulges.
The next step would getting hold of a cheap multi meter and take readings if you can't spot it visually.
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 6 Old 09-01-2011, 08:59 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I had the same problem, it was ONE single, small ground wire that was split/broke and killed everything. Soldered it back and was golden
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4 of 6 Old 09-01-2011, 09:37 PM
4Tom
Rubber door boot clips off from door you can do this by hand easily.
The door step cover is clipped in place. It can be pried up by hand.
Under the cover is screws think it's two.
The upper part of panel is clipped in.
Once panel is off access to wiring in body is possible.
I had orange/white cable broken and black showing damage.
I cut cables at point of damaged.
Pulled one side back into body and soldered on extra length of cable using heat shrink for insulation feed it back through boot and soldered it to other part of cable again using heat shrink for insulation. Clip back on boot
Refitted panel and door step cover job done.
WJ 2001 3.1TD
Tom
4Tom is offline
post #5 of 6 Old 09-02-2011, 02:31 AM Thread Starter
Bubba3200
Thanks all!!!
post #6 of 6 Old 09-02-2011, 06:08 AM
dutch724
I found it easier to take the door off to work on the wires, instead of trying to do it in a crack.
dutch724 is offline
Door controls DISABLED when driver door is OPEN? infinitempg WJ Grand Cherokee Forum 4 03-21-2012 11:28 AM
Driver's Door Controls - Do Not Work with Door OPEN. infinitempg WJ Grand Cherokee Forum 3 08-21-2011 12:21 PM
My driver side rear window is stuck open! williahk WJ Grand Cherokee Forum 10 07-26-2011 12:48 PM
2004 Laredo No Power to Driver Door Flyusaf2002 WJ Grand Cherokee Forum 2 05-05-2011 03:11 PM
Windows and Door locks done work when door is open radryan505 WJ Grand Cherokee Forum 6 02-24-2011 09:05 PM
