Post Pictures of 2/2.5" Lift - Page 4 - JeepForum.com
post #46 of 118 Old 03-27-2013, 06:04 PM
Barricade643
I'm looking to get a budget boost sooner than later, does anyone have a good pic of a wj flexing with this lift?
Barricade643 is offline
post #47 of 118 Old 03-27-2013, 06:09 PM
doorjamm
2" fat bobs coil spacers with Toyo A/T's 245/75/16
This is with sway bars connected (addco rear -stock front)
image-600894048.jpg   image-2792576610.jpg   image-3566603475.jpg   image-855951193.jpg
doorjamm is offline
post #48 of 118 Old 03-27-2013, 06:11 PM
doorjamm
And how it looks sitting flat
doorjamm is offline
post #49 of 118 Old 03-27-2013, 06:16 PM
Barricade643
Not to bad, looks like it would flex a lot more than I thought. Even more if the sway bars are disconnected.
post #50 of 118 Old 03-27-2013, 06:42 PM
Gabedingoxx
2003 WJ
This is my wj on 2 inch coil spacers with 31s. Got the x flex 4 inch sittin in my garage waitin for my new wheels and tires to get here then she'll look real good
Gabedingoxx is offline
post #51 of 118 Old 03-27-2013, 06:56 PM
Jeepin99WJ
So what do you all have to get and install for a 2" budget boost? This will remain my DD so I don't want anything crazy...
Jeepin99WJ is offline
post #52 of 118 Old 03-27-2013, 07:00 PM
dippedWJ
Spacers and shocks.
dippedWJ is offline
post #53 of 118 Old 03-27-2013, 07:10 PM
Jeepin99WJ
Originally Posted by dippedWJ
Spacers and shocks.
Does it matter what type of spacers? I have seen that blistein 5100 are good. What about skyjackers?
post #54 of 118 Old 03-27-2013, 07:17 PM
dippedWJ
I'm not sure how important the type of spacer is. I've never had a bb. I did a 2.5" coil and shock lift. I found it was around the same price as doing a bb with shocks. Bilstein 5100 is one of the best shocks you could buy. I have pro comp 8000s on mine and they ride just fine. Message Kolak and ask him what spacers he recommends. He could definitely help you.
dippedWJ is offline
post #55 of 118 Old 03-27-2013, 07:26 PM
Jeepin99WJ
How much was your lift and what was all involved in doing it?
post #56 of 118 Old 03-27-2013, 07:42 PM
dippedWJ
Well seeing your jeep is a 99 (from your name) you definitely will need new isolators if you go the route I did. They're $100 for the whole set of 8 from Kolak. Then the 2.5" lift kit from fat bobs with the coils and shocks was $299.99 plus shipping was around $50. It took a good 6 hours to put on. You'll need a 15mm socket and def a breaker bar. I'd recommend buying some pb blaster to try and help loosen the bolts holding the rear shocks in place. They were insanely tight, and mines an 02. I even had one break and I have it ghetto rigged til I can get my hands on a sawsall tomorrow at work. I didn't rent a coil spring compressor, I just put a jack under the control arm to hold it up and removed the bolts attaching to the tie rod. After the bolt was removed, I slowly lowered the jack and the coil stretched out fully. Then you can push down on say the rotor and it'll help free the coil spring so you can pull it out. I also had to do this when putting the longer springs in. I even had to use my jack to spead the space open to get the springs in. (I rented a compressor but it was the wrong style) ill be honest the lift kit was a pain in the ***, not saying all wj lifts will go as rough as mine did. But every single bolt took all I had with a breaker bar to turn. And not just to break it free, it was that tight all the way out. It sucked, bad.
dippedWJ is offline
post #57 of 118 Old 03-27-2013, 08:02 PM
Jeepin99WJ
Is your lift better than a coil spacer lift?
post #58 of 118 Old 03-27-2013, 08:08 PM
dippedWJ
Yes
dippedWJ is offline
post #59 of 118 Old 03-27-2013, 10:12 PM
Wj168900
My matte black dipped 02 4.0l WJ with 2.5" coil lift from Fat Bobs and 1.5" wheel spacers sitting on 265/70r16 ATs
Hey what kind if led lights are those and how do you like them?
Wj168900 is offline
post #60 of 118 Old 03-27-2013, 10:41 PM
bergoff
I'm really considering doing a lift like you guys. My only concern is that I use me WJ to pull my 17ft ski boat. Will I have any problems? I will pry stick with stock tire height.
bergoff is offline
