possible stuck caliper? pulls hard left when braking - JeepForum.com
post #1 of 11 Old 04-24-2013, 11:55 PM Thread Starter
GODMODEX
Title says it, my WJ recently got a 6.5 IRO critical path lift, and it now pulls hard left when I brake. It is aligned good, and everything is tight. When I apply the brakes, the harder I press, the harder it pulls left. It had this problem very slightly before but the lift and heavier tires must've amplified it, or it's something in the lift... I greased the caliper bolts, and it seems to have helped slightly, but it is still there. Does anyone else have brake steer or this type of problem due to the IRO long arm setup?
Anyways, main question, is does this sound like a seized caliper? it also pull to the right a little bit when I'm driving, enough to have to keep the steering wheel turned a bit while driving down the road. Any help? caliper seized? bad bushing somewhere? thanks guys
01 TJ, 32RH, 4.0, 8.8, hpd30, 35's, metalcloaks
07 CBR600RR, full Akra exhaust, PC V, etc.
GODMODEX is offline
post #2 of 11 Old 04-25-2013, 12:30 AM
Mp5ben
2005 WK
If you can find a parking garage to through it slowly with your windows down to listen for any grinding sounds, especially if it sounds like a caliper is stuck.
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #3 of 11 Old 04-25-2013, 12:32 AM Thread Starter
GODMODEX
no grinding sounds... I've been doing pretty much just that listening for anything clunking in the new lift etc. I can also freely spin both rotors, although one is a little harder than the other
GODMODEX is offline
post #4 of 11 Old 04-25-2013, 09:52 AM
oldfamilyguy
If that brake is on enough to make you pull it will be good and hot. You won't have to touch anything to know, just get close.
oldfamilyguy is online now
post #5 of 11 Old 04-25-2013, 02:30 PM
dsodko
Wj
I had the same problem with our "02" after new brakes all around. Found Passenger side caliper just hiccuped when it felt like it !
After working on cars for 50 years, when the Jeep wants to mess with you, you learn to roll with it.
GOOD LUCK !
dsodko is offline
post #6 of 11 Old 04-25-2013, 02:47 PM
sage39henry
When its pulling hard, put it in park, get out and feel your wheels. I assume one of them will be hott as hell. Recently, my drivers side was so hot i'd swear i could cook an egg on her... Lift, bigger tires, heavier wheels and mud do not help your calipers.
WHITE WJ LIMITED 4.7 242HD/ IRO arms w/ Rusty's 4.5in coils/Doetsch 5in Shocks/JKS Quicker Disco's/ D44a Spartan Locker/ Rigid Industries 10" light bar/ 33 12.50 15 Mickey Thompson MTZ/ V-5s
sage39henry is offline
post #7 of 11 Old 04-25-2013, 02:52 PM
Overstreet
this happen to me on the front left I felt more load on the engine and it not getting to speed as fast. Then started smelling brakes. thought it was another car got off the main highway and then saw smoke coming from my front wheel. I now have akebonos up front
Overstreet is offline
post #8 of 11 Old 04-25-2013, 02:54 PM
C101Commando
Heat is a great indicator of a stuck caliper, you might also try pulling the abs controler fuse to see if a messed up wheel sensor is unapplying the right side brakes. Free to check..
03 WJ, 4.7 Limited
C101Commando is offline
post #9 of 11 Old 04-25-2013, 03:50 PM Thread Starter
GODMODEX
Alright awesome guys thanks. It was way better this morning, after greasing the pins. Gonna tear down and clean my brakes, and bleed them tonight. Hopefully that solves it otherwise new caliper time
GODMODEX is offline
post #10 of 11 Old 04-26-2013, 08:07 AM
XHATCHx
2003 WJ
Sometimes a caliper rebuild is needed. I did this a year ago and it's like having new brakes. Stupid pistons.
XHATCHx is offline
post #11 of 11 Old 04-26-2013, 09:21 AM
texlurch
Good habit whenever you do pads is to push the piston almost all the way out in the caliper and clean the boots and pins real good.
They get a lot of dust and dirt buildup around pistons and can cause sticking.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
