Popping exhaust after new plugs and air filter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Popping exhaust after new plugs and air filter
Genright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!
Unread 06-24-2012, 09:20 AM   #1
boaterdave90210
I have a 99 wj with a 4.0. I took the air filter out to clean it and re-oil it, and while it was drying, I replaced all the spark plugs. When I put the cap thing back on the spark plugs, I made sure it was secure, and then tightened it down. After that was finished I put the newly oiled air filter back on and started it up, drove it about a mile and then back home. Thats when I noticed the check engine light and the exhaust popping with no rhythm. Any thoughts on what this could be?
boaterdave90210 is offline   Reply With Quote
Unread 06-24-2012, 09:31 AM   #2
rcwj04
rcwj04's Avatar
It's a misfire, one of the boots is not seated on the spark plug properly, same thing happened to me
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
2004 WJ 107k
2" BDS coils & Billy 5100's, Addco rear swaybar with energy bushings(planning on getting front also)
K&N FIPK, glasspack, plasti-dipped badges, 17" moabs, HID's, 245/65/17 Cooper Discover AT3, Rola rack, Fawkes stand alone shackle tabs
rcwj04 is offline   Reply With Quote
Unread 06-24-2012, 10:22 AM   #3
MuddyWJ
^x10
MuddyWJ is offline   Reply With Quote
Unread 06-24-2012, 01:04 PM   #4
86cj74.2L
86cj74.2L's Avatar
Or their not in the proper order read the codes and it will tell you which cylinder to look at
86cj74.2L is offline   Reply With Quote
Unread 06-24-2012, 01:50 PM   #5
rcwj04
rcwj04's Avatar
Its kinda hard to mess up the order considering its a coil rail, but I guess anything is possible hahaha
Unread 06-24-2012, 02:15 PM   #6
86cj74.2L
86cj74.2L's Avatar
Do the on off on thing three times and see what misfire code you got. I keep forgetting their wasted spark now.
It's not the first time there was a bad plug in a new box.
Or put your old plugs back in and see if it goes away.
Is the check engine light flashing? Or on solid?
Unread 06-24-2012, 03:14 PM   #7
billzcat1
Chicken in a Turkey Suit
2003 WJ
What plugs did you use? Remember the 4.0 is picky about plugs...
billzcat1 is offline   Reply With Quote
Unread 06-24-2012, 07:24 PM   #8
boaterdave90210
I pulled off the rail, put it back on and it worked fine! I guess it was just picky :P Thanks guys!!
