Popped my cherry - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Popped my cherry
Dana 30/ Dana 44 Chromoly shaft Kits- ECGSFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201
Unread 04-06-2014, 07:12 PM   #1
namtrah
namtrah's Avatar
Wj Popped my cherry
I owned a 94 XJ years ago and I miss that rig. I regret it going to the salvage yard as I sent it away with plenty of aftermarket parts on it...what a fool! Fast forward to 2007. Back from Iraq and needed a new Jeep in the driveway. The ex wife and I bought a 04 WJ Laredo, my current rig. The WJ has been flawless for reliability since 2007 until our divorce. After I moved out in 2012, the poor WJ saw no maintenance except for an oil change. By 2013, many parts started to show wear at 130k miles. I have dumped a lot of money into it and continue to move toward my goals with my rig. For now, I replace lots of parts that are just worn.
Today, I changed my first u-joint. Big deal, right? Well, I attempted this on my XJ and failed. I rounded off every bolt and gave up. I've learned so much along the way and now I have successfully removed my front driveshaft, inspected the rezeppa joint and changed the u-joint. I'm pretty damn happy and another new part on an already reliable vehicle. I'll add this experience to my book of knowledge pertaining to the WJ. Onward and upward as I continue to aim for a long arm lift kit.
2004 WJ Laredo-4.0L-Amsoil Synthetics-K&N FIPK-Borla Catback with Hi-Flow Cat-2" RC BB JKS Track Bar and Frt BPE, ADDCO Rear Sway Bar Future: putting together 4" lift
namtrah is offline   Reply With Quote
Unread 04-06-2014, 07:16 PM   #2
thevanillaninja
Congrats on completing one of my most hated jobs on a truck. U joints are horrible unless you have a vice, press, and more patience than I!
There is nothing like learning while enjoying what you're doing. Continue on, next year you'll be rebuilding a diff or the engine or something else!
02 Overland - the Heap
89 XJ - the Cheap
91 Parts XJ
Kodiak, AK // MK2, USCG
thevanillaninja is offline   Reply With Quote
Unread 04-06-2014, 07:17 PM   #3
losttech
losttech's Avatar
Its nice to know its done right and where everything is its a good feeling.
2000 Jeep grand Cherokee
I6, selectrac, dana 30 front 44a rear
Stock not lifted.
losttech is offline   Reply With Quote
Unread 07-08-2014, 09:12 PM   #4
namtrah
namtrah's Avatar
Wj Another chapter...power steering
Added onto my Jeep resume today. Replaced power steering pump and pulley as well as hoses. I also installed a filter and cooler to the mix. All went pretty smooth and the steering feels responsive again. The pump had been leaking and neglected for a couple years. Nice to have new parts and a new chapter under my belt.
Also installed new front axle shafts and wheel hub units the day before, smooth install with no issues except a little corrosion that PB Blaster took care of.
Still working on upgrading from a 2" BB to a 4" lift. I have to get springs blasted and repainted...rattle can rustoleum of course! Also will be installing a cabin filter to keep all the dust out. I certainly do enjoy completing mods or basic maintenance on my WJ.
Side note, that second pic of the axle shaft is not mine. I uploaded wrong pic and can't figure out how to remove it. Someone else's carnage.
Unread 07-08-2014, 09:57 PM   #5
namtrah
namtrah's Avatar
Wj
Couple pics of old stuff before I yanked it out. Make sure you get the removal and install tool for the pulley. My pal decided to try and punch and busted my old one all to ****. Right tool for the right job. Also make sure you don't press the pulley on too far, it will not turn easy, thus no good. Ask me how I know
