Pop from Passenger window, now won't roll up - JeepForum.com
post #1 of 22 Old 06-09-2013, 02:24 PM Thread Starter
justn
Wj Pop from Passenger window, now won't roll up
I rolled down the front passenger window today, and when I rolled it back up I heard a somewhat loud pop come from it. I stupidly started to roll it back down and when I noticed it was rolling down way too fast I let off the switch and it continued on its way down. Tried rolling it back up and it wouldn't.
Here's what I know so far, the motor still seems to work, I here it make noise for a bit when I try rolling it up or down.
There's a loose metal cable in the door, and I think that may be what the pop came from. When I lift the window up, it stops about 3 inches from being fully up and that loose cable becomes tight.
Any info or advice on what to do is appreciated.
My Build Thread for the old WJ
http://www.jeepforum.com/forum/f197/justns-build-thread-1236882/
justn is offline
post #2 of 22 Old 06-09-2013, 02:35 PM
offroading.net
offroading.net's Avatar
The plastic bracket the cable ataches to has snapped, common fault. I think there is a repair to fix it but I had one go on me last week & I scored a new winder mech from ebay for 70 ($100ish) so just swapped the whole unit out.
Steve Wright
'02 4.7 v8 WG Limited
'99 4l I6 WG Limited
'16 Renegade Limited, Wifey Wagon
Previous Jeeps- 8 XJs, an MJ, a WJ, 2 TJ's & 2 KJs
offroading.net is offline
post #3 of 22 Old 06-09-2013, 04:48 PM
1999wjlimited
Mine did the same thing 6 months ago I it was the plastic clip that broke. I just got a whole new window motor assemble for around $65 from autozone. It only took about an hour and a half to replace.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #4 of 22 Old 06-09-2013, 05:21 PM
DDog1
Try Rockauto .com . Buy the brand with the lifetime warranty. Fairly easy replacement. About $60.00 or so for the part. The plastic parts embedded in the metal rail assembly are known to fail over time. Especially in the colder climates when the windows are frozen up and you hit the button. I've replaced both front doors a couple of times over the years....
DDog1 is offline
post #5 of 22 Old 06-09-2013, 09:51 PM Thread Starter
justn
Thanks guys. Is the more expensive Dorman one that claims to be a little beefier than stock worth the money, or is the TCY brand ok too? The Dorman is about $65, and TCY is $45, and both say they have a liftetime warranty.
justn is offline
post #6 of 22 Old 06-10-2013, 06:22 AM
DDog1
I had used the Dorman brand. Can't really say which is better myself though since I've only used the Dorman part.
DDog1 is offline
post #7 of 22 Old 06-10-2013, 02:26 PM
YZ212
2003 WJ
Any one think that packing the plastic clip with jb weld or epoxy would help stop the plastic piece from failing?
03 Limited 4.7 4" IRO Long arm rear 4.5" custom radius arm front Currie Fab 9" hp front
247-231 swap BFG TA KO 315/70/17 Black Rock 909 Type D wheels 17x8 5x5 and 5.5 bolt pattern 4.5" backspace
YZ212 is offline
post #8 of 22 Old 06-10-2013, 04:24 PM
DDog1
It might be possible to fabricate something or reinforce them, maybe a machine shop or metal worker could fabricate something...there are a number of nylon plastic parts interconnected/embedded with metal with these regulators so while the thought crossed my mind as well...I've just resorted to replacing them as they break considering the parts I have are now under a replacement warranty. Doesn't address the concern about when they might give out next but that's where I am at with these....
DDog1 is offline
post #9 of 22 Old 06-12-2013, 06:13 PM Thread Starter
justn
Finally replaced the window regulator. Pretty easy fix. Just a few "how the heck does this work?" moments.
justn is offline
post #10 of 22 Old 06-13-2013, 11:45 AM
cubalz
Gotta replace the passenger front Window regulator. It broke last week. Not looking forward to it....
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #11 of 22 Old 06-13-2013, 11:49 AM Thread Starter
justn
Its not that bad. Just watch the video 1a auto has: https://www.youtube.com/watch?v=NGkPoOd2zi8
They go through everything step by step. The only thing that was hard to figure out was how to disconnect the window motor from the wiring harness. There was a red sliding lock that I had to slide, then push down a black tab and pull it apart. It'll come apart easy once you have the locking thing out of the way.
justn is offline
post #12 of 22 Old 03-08-2017, 08:22 PM
atty
Thank You
I know this is an old thread, but the same thing happened to me this afternoon as I was pulling into the house. I thought somebody had taken a shot at me. That "bang" was deafening.
For the moment, a 20" piece of wood is keeping the window up. Will attack again when the new regulator arrives from Rockauto.
In any event, I thank you for the post. Saved me a lot of grief trying to figure out WTF.
atty is offline
post #13 of 22 Old 03-08-2017, 09:46 PM
MOTOWN
Excellent video! I have all four regulators/motors new from TYC waiting on time to install them.
MOTOWN is offline
post #14 of 22 Old 03-09-2017, 10:16 AM
cdplayer
Wj window regulator pop
On more of a budget than most. So when my regulator, still having a good running motor and cable, did it's POP sound and the glass fell into the door, I recovered the part of a used regulator that broke.
It's been just over two years now since the repair. Best $4 I ever spent!
cdplayer is offline
post #15 of 22 Old 03-09-2017, 05:32 PM
jserna
1987 YJ Wrangler
WWWWooooohhhhoooo!!!!!! I am joining the club to. My passenger regulator went out yesterday afternoon. I used a small vice grip to keep the window up till I get the part.
jserna is offline
