Please help grand cherokee issue stalling - JeepForum.com
post #1 of 7 Old 12-17-2013, 03:27 PM Thread Starter
meatball13djb
Here's the low down. Baught a 2002 4.0 grand Cherokee a couple days ago the known issue was engine stalling when put in reverse. I go to start it today. Batterys dead. So I buy a new battery along with new posts. I start it and it wouldn't idle. I'm assuming the battery change messed up the iac because I ran it for a while and its back to normal. Still has the reverse stall. Then I hear clicking the evap canaster solenoid plus fuel pump is clicking .......I need help to fix my issue .....txt me 517 306 7245 names dylan.
meatball13djb is offline
post #2 of 7 Old 12-17-2013, 07:59 PM Thread Starter
meatball13djb
Bump
post #3 of 7 Old 12-17-2013, 08:28 PM
bcriverjunky
Check fuel pressure, pump could be on it's way out
bcriverjunky is offline
post #4 of 7 Old 12-17-2013, 08:58 PM
red2black00
I had a problem with mine stalling but not particularly in reverse but mine was because my fuel filter was stopped up I would try that first. It's much cheaper than the pump and easier to should take no more than 10 minutes and if it doesn't fix it then a new filter is always better than an old one
red2black00 is offline
post #5 of 7 Old 12-18-2013, 08:56 AM Thread Starter
meatball13djb
Thanks for the help guys will try fuel filter first will post if issue is fixed
post #6 of 7 Old 12-18-2013, 07:50 PM
runningonempty
Wj
isn't the fuel filter buried with the fuel pump in the gas tank?
runningonempty is offline
post #7 of 7 Old 12-18-2013, 09:19 PM
red2black00
It is right in front of the gas tank with 3 lines on it
