Please help - JeepForum.com
post #1 of 6 Old 09-26-2013, 02:27 PM Thread Starter
xj_96_FP
Please help
My parents have 2001 grand and yesterday my dad backs down the drive way heard some sort if grinding noise when he steps on the brake, then when it goes into drive but non of the lights or blinkers or radio worked, if you put it in park it makes another grinding noise. The lights do come back on in park. They go off when it's put in gear.
Any suggestions?
xj_96_FP is offline
post #2 of 6 Old 09-26-2013, 04:41 PM
wickedwj99
What is the spec on the grand engine trans model? How's the fluid levels in the trans was the parking brake off
I have also heard those stick on chrome vents from Walmart add like 75+ HP..
wickedwj99 is offline
post #3 of 6 Old 09-26-2013, 05:10 PM
tim0
Check all your battery and ground cables at the battery, engine, body and starter to insure you dont have a lose connection.
Bad connections can cause all kinds of electronic issues, even cause the electronic transmission to go in 2 gears at once.
tim0 is offline
post #4 of 6 Old 09-26-2013, 05:17 PM Thread Starter
xj_96_FP
It's a straight 6 I'm not sure the trans, is a lareado
xj_96_FP is offline
post #5 of 6 Old 09-27-2013, 12:28 PM Thread Starter
xj_96_FP
How many grounds are there? Block and battery...
xj_96_FP is offline
post #6 of 6 Old 09-30-2013, 08:13 PM Thread Starter
xj_96_FP
Ok so I resolved the issue, it was the starter shorting out, replaced it and works perfectly
xj_96_FP is offline
