pinion bearing? - JeepForum.com
post #1 of 8 Old 04-17-2013, 11:44 PM Thread Starter
as350b3e
pinion bearing?
My 99 gc laredo pinion seal is leaking. After driving it for about 400km I could hear noise coming from the rear when coasting on the hwy. It does not make noise when driving for a short time. Is this a sign that my pinion bearing is bad?
The jeep has 243000km, bought it 1 year ago for $3700.
How much labour is a dealer going to charge for it? Is it worth getting it done?
There are other issues with this jeep such as airbag light on, engine surging during first minute of driving, O2 sensor problem, shocks and rear axle seals......
as350b3e is offline
post #2 of 8 Old 04-17-2013, 11:53 PM
cykaaro
Axle seals are pretty straight forward, and makes sense to do them at the same time as the pinion. Is there play in it at all? If its making noise make sure you have fliud in and doesn't run too low. This could be why yiur hearing it. Had my one axle seal seaping but stopped. Will hav e everything done in a couple of weeks as its a matter of time before it leaks again. If the 02 sensor is bad fairly inexpensive to change it. Airbag couid be the modulke going flakey. Would say give it a good tune up and go from there. If its a 4.0 use champion truck plugs. They don't like the fancy smancy type.
As for dealership prices? Here in Ont. They're pretty pricey. If you can find a small honest shop that does good work, I'd say go there. I only go to the dealership on things I absolutely have to only. ,
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 8 Old 04-18-2013, 12:29 AM Thread Starter
as350b3e
I had the spark plugs changed at canadian tire. I think they used champion plugs.
The shop rate in fort mcmurray is a whopping crazy $200/hour.......
I am sure I can change the pinion seal myself but not the bearing.
Just today I had the windshield replaced at speedy glass in edmonton for $300.
Picked up a napa gold fuel filter today for $70 to see if it will get rid of the surging. I have a feeling that somehow the fuel pressure does not build fast enough after starting the engine. The surging happens only during the first minute of driving. Once the surging stops it has never done it again until I turn off the engine. It is also intermittent. Sometimes it does not happen for days and some days it happens a few times per day. It happens with a cold or hot engine. I cleaned the tb, changed the tps and also cleaned the idle control valve. Idle is at 600 rpm. When the surging happens and I apply too much throttle the surging does not stop and the check eng7ne light comes on, applying very little to no throttle will stop the surging and the the engine runs just fine.......
as350b3e is offline
post #4 of 8 Old 04-18-2013, 08:34 AM
cykaaro
That's insane! I thought here was bad. That's like double! What code does it throw? Might help track down the issue.
cykaaro is offline
post #5 of 8 Old 04-18-2013, 02:19 PM Thread Starter
as350b3e
The code is P0138.
as350b3e is offline
post #6 of 8 Old 04-18-2013, 05:18 PM
cykaaro
http://www.jeepforum.com/forum/f11/c...or-2-a-767077/
cykaaro is offline
post #7 of 8 Old 04-26-2013, 07:33 PM Thread Starter
as350b3e
The rear pinion yoke is tight with no radial play. The rear diff had enough fluid and I filled it up again (2 large syringes were needed).
OK the check engine light comes on and then goes out again. Is that normal? If so how many starts or starts/engine running duration is needed for the light to go out?
In the beginning I had only code P0138, 2 weeks ago I rechecked again if there is another code that came up and I got P0138 and P0141. The code P0141 code is now gone it only shows the P0138 code and then reads "done" (Odometer).
Can also someone explain how this O2 sensor works? I am not sure if I understand this correctly but is there a heating element inside? If so, that would explain the intermittent engine surging I have during the first minute of driving. Again the surging happens regardless if the engine is warm or cold.
Is the O2 sensor for sure bad or could something else trigger the O2 sensor code?
Any ideas?
as350b3e is offline
post #8 of 8 Old 04-26-2013, 08:58 PM
lazyWJ
2006 XK Commander
I saw that CT was looking for a department manager in Fort Mcmoney, salary was something like $80k/yr. Now I know how they can pay that much!
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
