Pictures of 3 Inch Lift and 245/70/17 Tires. Go! - Page 3 - JeepForum.com
post #31 of 69 Old 03-07-2013, 10:44 AM
Merc1973
Originally Posted by bmandubj10 View Post
Thank you for your response are you running the 3 inch sway bar end links in the rear or do you have 4 inch ones?
I have the 4" Zone endlinks in rear and the swaybar angle is much better. I have the OEM links up front which ride better than extending them.
IMO, at stock height: the front factory links are too long and the rear factory links are too short.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #32 of 69 Old 03-07-2013, 10:59 AM
JimmydaGreek
2015 JK Wrangler
I'm running the 4" ones but either one will work since we're only talking an inch here.
2015 JK Unlimited Rubicon Loaded
2002 WJ Ltd 4x4 4.7L Upcountry/Selectrac
JimmydaGreek is offline
post #33 of 69 Old 03-07-2013, 12:04 PM
Merc1973
You're not kidding about twins, lol.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #34 of 69 Old 03-07-2013, 12:05 PM
JimmydaGreek
2015 JK Wrangler
Right! lol...
post #35 of 69 Old 03-07-2013, 09:19 PM
Wenatchee_Kid
Originally Posted by jmac21 View Post
1"upcountry and a 2"rough country lift with 245/70 17 bf goodrich all terrains. Im in love hahaha
Did you spring for a shop to do it?
Let us know if you lose any handling.
Wenatchee_Kid is offline
post #36 of 69 Old 03-07-2013, 10:47 PM
StealYaFace
Yo JimmydaGreek, I am about to install your same lift/tire combo minus the 3/4" spacers...did you encounter a lot of rubbing when you first installed the 3" OME HD springs and 265/70/17 BFG A/T's?
The Jeep is looking great by the way!
StealYaFace is offline
post #37 of 69 Old 03-07-2013, 11:00 PM
Sweetjackal
I have the IRO 3" and run JK take off's i got for $200.
255/55/18
Minor rub in the back, fill the wheel wells nicely.
99 XJ SOLD
00 WJ Rust Bucket SOLD
01 WJ 4.7, 247, Zone 4 Lift
Sweetjackal is offline
post #38 of 69 Old 03-08-2013, 09:22 AM
bmandubj10
2003 WJ
Thank you so much I will just order the rear IRO 4 inch sway bar end links. I am also going to throw in the a arm spacer as well.
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #39 of 69 Old 03-08-2013, 11:41 AM
JimmydaGreek
2015 JK Wrangler
Yes, lot's of rubbing on even slight turns and in reverse while turning big time. Those BFG's are meaty as heck! I installed the RC 3/4" spacers in front and OME 10mm spacers in back and that helped a lot but I still need to trim if I'm going to offroad and flex. If you don't want to trim and are going to go with BFG's, I'd recommend sticking to 245's, but I wanted the bigger tire.
Thanks...
post #40 of 69 Old 03-10-2013, 10:01 AM
StealYaFace
Do you think I'd be able to trim enough to run the OME HD set up with the BfG's without rubbing?should I add the spacers? Ive been warned not to go over 3" of lift. This is my daily driver, but it will see its fair share trail time.
post #41 of 69 Old 03-10-2013, 10:04 AM
03azwj
2003 WJ
That's what I run and I trimmed the front a bit and now only rub at full lock and fully flexed.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #42 of 69 Old 03-10-2013, 11:10 AM
StealYaFace
You got any pictures of your set up?
I just installed the OME HD springs the other day and it would suck to have to pull it apart to add some spacers. A little trimming is cool with me...
post #43 of 69 Old 03-10-2013, 11:19 AM
03azwj
2003 WJ
I know what you mean on the spacers. I actually have a set to install but I'm waiting on the fronts so I can do them all at the same time. Original install of springs shocks and trackbar took about 3 hours. Second time for just spacers should take a lot less time.
03azwj is offline
post #44 of 69 Old 03-10-2013, 12:32 PM
Speedy
I have 2" on mine, the rims : Ultra Goliath 17"x 8" has a offset: 30mm and backspacing: 5.66". I have a small rubb on the bumper when reversing and turning.
_________________________
Nothing is impossible, it just take some more time.....
Speedy is offline
post #45 of 69 Old 03-10-2013, 01:05 PM
jmac21
my buddy is a mechanic so him and i did it at his garage, it took like 3.5 hours. the front shocks were a pain in the a** to get out but we got it. no loss of handling what so ever, she drives like a dream. i was debating between the bfg all terrains or the goodyear wranglers, and im very impressed with the bfg's. surprisingly very quiet ride
jmac21 is offline
