Pictures of 3 Inch Lift and 245/70/17 Tires. Go! - JeepForum.com
post #1 of 69 Old 03-04-2013, 08:15 PM Thread Starter
DCJosh
Wj Pictures of 3 Inch Lift and 245/70/17 Tires. Go!
Hey everyone,
I really want to get some ideas for lift and tire options. I have searched through the picture and suspension thread, but it seems that everyone is running bigger lifts and tires then what I am looking for.
I would like to keep it at 3 inches and I think I am going to go with the IRO set up. Are there other options I should take a look at that I'm missing?
Also, from what I have learned here in the forums a 245/70/17 is going to be the largest tire that I can hold in the spare tire well. If I am off, let me know.
If you are running this set-up and you have some pictures to share that would be appreciated.
If you have links to other sites or reviews on products, those are helpful as well.
Thanks a lot!
Josh
DCJosh is offline
post #2 of 69 Old 03-05-2013, 12:38 PM
Merc1973
Im running 255/70/17 with OME medium and .75" spacers up front. You're correct, any tire bigger than the one you stated does NOT fir the tire well.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #3 of 69 Old 03-05-2013, 02:39 PM
JimmydaGreek
2015 JK Wrangler
I'm running 265/70/17 OME HD 3" springs, Bilstein 5100 shocks and 3/4" spacer up front, OME 10mm spacer in back, oh and 1.5" wheel spacers. With BFG AT's I need to trip the inside lower of the front bumper. Contact Kolak for all your lifting needs.
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
post #4 of 69 Old 03-05-2013, 02:40 PM
JimmydaGreek
2015 JK Wrangler
Nice rig Merc, we're twins just different colors, lol.
post #5 of 69 Old 03-05-2013, 08:57 PM
Merc1973
I know i saw that! Got anymore pics? I want to see it with the wheel spacers...
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 69 Old 03-05-2013, 09:32 PM
bmandubj10
2003 WJ
I have a similar setup look at my sig and I to run 3/4 spacers. I have trimmed downed the front bumper and need to do the rear as on the trail I rub terrible on the trail in the rear. It rubs so bad that i had to roll the rear fenders on one spot in the rear. I just got all four new lower isolators and I am going to order KOR 3/4 spacers and trim up the rear more to see if that helps. My only other options is to sell my wheels and size down to some 16 inch wheels with 31's. Anybody have any thoughts? Nice pictures of your jeeps guys in this thread, do you guys take yours off road?
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #7 of 69 Old 03-05-2013, 11:57 PM
PowderHound
2003 WJ
LMGTFY
LOL this thread comes up first. I'm also building around this tire size (daily driver/spare location is important). This setup will rock out some nasty stuff with a skilled driver, quadradrive and airing down a little. It has a larger diameter than most 31's on a 15 inch rim. The 31x10.50x15 BFG's KM1's on my XJ only measured 30 inches tall with a tape measure. WJ's flex very well with a 2-3 inch lift and you will be able to STUFF this tire size. Get some front disco's and you will be able to make TJ's with body lifts jealous.
2003 WJ♦Inferno Red Limited(4.7 H.O., Vari-Lok axles)♦OME HD/BILLY 5100S♦IRO t-case skid, adj. tb, sway links♦Moog SS♦Factory tow package w/harness & tow hooks♦ Amp/12 sub box♦new bad b**ch passenger♦1993 XJ country♦lift/muds/winchbumper-sold♦build thread instead of long A$$ sig soon...
PowderHound is offline
post #8 of 69 Old 03-06-2013, 12:25 AM
CruizinKev
too bad I only see red X. can't see pic
- Kevin -
2000 Jeep Grand Cherokee 4.7 Dailydriver
1979 Chevrolet Monte Carlo LS3 6.2 T56 Full Resto Project
CruizinKev is offline
post #9 of 69 Old 03-06-2013, 12:51 AM
03azwj
2003 WJ
Here's my WJ with the OME HD lift. You can check out all the details in my sig.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #10 of 69 Old 03-06-2013, 04:14 AM Thread Starter
DCJosh
That is exactly what I am looking for, thanks! Did you have to do any trimming of the bumpers with those tires? I am looking to get the IRO 3" lift, is that much more than the OME?
DCJosh is offline
post #11 of 69 Old 03-06-2013, 06:39 AM
madslynge87
I'm planning on doing the OME HD lift as well... The tire size i'm thinking of putting in there is 265/70/17. Would it be a good idear to add som spacers? Mayber inch in front and ,25 inch in the rear?
madslynge87 is offline
post #12 of 69 Old 03-06-2013, 10:02 AM
JimmydaGreek
2015 JK Wrangler
Sorry, something happened to my photobucket folder. Here is a side pic and I'll take more from the front and back so you can see with the 1.5" spacers.
post #13 of 69 Old 03-06-2013, 10:10 AM
JimmydaGreek
2015 JK Wrangler
Here's a pic with the front wheel off and all the new parts: OME HD 3" spring, Bilstein Shock, JKS Quicker Disco, JKS Adj Trackbar, RC 1.5" hubcentric wheel spacer, all new Moog spring isolators. I just ordered also all 4 front IRO adjustable control arms and all 4 Moog Tie Rod ends.
post #14 of 69 Old 03-06-2013, 10:28 AM
bmandubj10
2003 WJ
My picture is the White WJ 6 post down and I am running 265/70r17 with General Grabber AT2's. I rub terrible in the rear on the trail.
post #15 of 69 Old 03-06-2013, 11:08 AM
Poseidon
Upcountry, with a 2" BB, Bilsteins:
Tires are Cooper AT3's 245 70 R17
Poseidon is offline
