-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Pictures of 3 Inch Lift and 245/70/17 Tires. Go! (http://www.jeepforum.com/forum/f310/pictures-3-inch-lift-245-70-17-tires-go-1488144/)
DCJosh 03-04-2013 08:15 PM
Hey everyone,
I really want to get some ideas for lift and tire options. I have searched through the picture and suspension thread, but it seems that everyone is running bigger lifts and tires then what I am looking for.
I would like to keep it at 3 inches and I think I am going to go with the IRO set up. Are there other options I should take a look at that I'm missing?
Also, from what I have learned here in the forums a 245/70/17 is going to be the largest tire that I can hold in the spare tire well. If I am off, let me know.
If you are running this set-up and you have some pictures to share that would be appreciated.:cheers2:
If you have links to other sites or reviews on products, those are helpful as well.
Thanks a lot!
Josh
Merc1973 03-05-2013 12:38 PM
Im running 255/70/17 with OME medium and .75" spacers up front. You're correct, any tire bigger than the one you stated does NOT fir the tire well. :(
http://i64.photobucket.com/albums/h1...ps0b02236f.jpg
JimmydaGreek 03-05-2013 02:39 PM
I'm running 265/70/17 OME HD 3" springs, Bilstein 5100 shocks and 3/4" spacer up front, OME 10mm spacer in back, oh and 1.5" wheel spacers. With BFG AT's I need to trip the inside lower of the front bumper. Contact Kolak for all your lifting needs. ;)
http://i154.photobucket.com/albums/s...k18/OMEpic.jpg
JimmydaGreek 03-05-2013 02:40 PM
Nice rig Merc, we're twins just different colors, lol. :cheers:
Merc1973 03-05-2013 08:57 PM
I know i saw that! Got anymore pics? I want to see it with the wheel spacers...
:2thumbsup:
bmandubj10 03-05-2013 09:32 PM
1 Attachment(s)
I have a similar setup look at my sig and I to run 3/4 spacers. I have trimmed downed the front bumper and need to do the rear as on the trail I rub terrible on the trail in the rear. It rubs so bad that i had to roll the rear fenders on one spot in the rear. I just got all four new lower isolators and I am going to order KOR 3/4 spacers and trim up the rear more to see if that helps. My only other options is to sell my wheels and size down to some 16 inch wheels with 31's. Anybody have any thoughts? Nice pictures of your jeeps guys in this thread, do you guys take yours off road?
PowderHound 03-05-2013 11:57 PM
LMGTFY
LOL this thread comes up first. I'm also building around this tire size (daily driver/spare location is important). This setup will rock out some nasty stuff with a skilled driver, quadradrive and airing down a little. It has a larger diameter than most 31's on a 15 inch rim. The 31x10.50x15 BFG's KM1's on my XJ only measured 30 inches tall with a tape measure. WJ's flex very well with a 2-3 inch lift and you will be able to STUFF this tire size. Get some front disco's and you will be able to make TJ's with body lifts jealous.
CruizinKev 03-06-2013 12:25 AM
too bad I only see red X. can't see pic
03azwj 03-06-2013 12:51 AM
2 Attachment(s)
Here's my WJ with the OME HD lift. You can check out all the details in my sig.
Attachment 579291
Attachment 579289
DCJosh 03-06-2013 04:14 AM
That is exactly what I am looking for, thanks! Did you have to do any trimming of the bumpers with those tires? I am looking to get the IRO 3" lift, is that much more than the OME?
madslynge87 03-06-2013 06:39 AM
I'm planning on doing the OME HD lift as well... The tire size i'm thinking of putting in there is 265/70/17. Would it be a good idear to add som spacers? Mayber inch in front and ,25 inch in the rear?
JimmydaGreek 03-06-2013 10:02 AM
Sorry, something happened to my photobucket folder. Here is a side pic and I'll take more from the front and back so you can see with the 1.5" spacers.
http://i154.photobucket.com/albums/s...eep/OMEpic.jpg
JimmydaGreek 03-06-2013 10:10 AM
Here's a pic with the front wheel off and all the new parts: OME HD 3" spring, Bilstein Shock, JKS Quicker Disco, JKS Adj Trackbar, RC 1.5" hubcentric wheel spacer, all new Moog spring isolators. I just ordered also all 4 front IRO adjustable control arms and all 4 Moog Tie Rod ends.
http://i154.photobucket.com/albums/s...p/IMG_2744.jpg
bmandubj10 03-06-2013 10:28 AM
My picture is the White WJ 6 post down and I am running 265/70r17 with General Grabber AT2's. I rub terrible in the rear on the trail.
Poseidon 03-06-2013 11:08 AM
Upcountry, with a 2" BB, Bilsteins:
http://perfectpix.smugmug.com/Other/...21445866-L.jpg
http://perfectpix.smugmug.com/Other/...20592395-L.jpg
Tires are Cooper AT3's 245 70 R17
The time now is 11:41 PM.
