"Perform service" on the overhead. - JeepForum.com
post #1 of 14 Old 08-29-2011, 05:38 AM Thread Starter
vwbuge
Is this just the reminder when you set the service intervals on the overhead console? I looked in my owner's manual and I can't get the thing to reset. Or could this be related to my airbag light coming on in the dash?
vwbuge is offline
post #2 of 14 Old 08-29-2011, 05:40 AM
mreed21
Yes just hit reset.
mreed21 is offline
post #3 of 14 Old 08-29-2011, 05:40 AM
Thomahawk
You have to Go to perform service at Overhead consol and hold the reset button for a while...
Buildthread
Thomahawk is online now
post #4 of 14 Old 08-29-2011, 07:01 AM
WJ04
Its just to remind you when to do an oil change, you can set it to where you want it. every 3000,3500,5000 etc
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #5 of 14 Old 08-29-2011, 07:40 AM Thread Starter
vwbuge
yes. I did it when I got the vehicle. I am having difficulty reseting it.
vwbuge is offline
post #6 of 14 Old 08-29-2011, 08:03 AM
Thomahawk
Hold or dobble click reset....
Buildthread
post #7 of 14 Old 08-29-2011, 09:02 AM Thread Starter
vwbuge
OK. I have held it for almost a minute, didn't work. I will try double clicking reset. I should do this when it pops up when starting the vehicle?
vwbuge is offline
post #8 of 14 Old 08-29-2011, 09:19 AM
Hack
2003 WJ
on mine I did it through the menu. After where you set the interval it says "reset service interval Y/N?". Never tried holding the reset button.
Hack is offline
post #9 of 14 Old 08-29-2011, 09:43 AM
Ideford Jeep
I've rest mine by changing the serivce interval & exiting the menu, and then changing it back again
Ideford Jeep is offline
post #10 of 14 Old 08-29-2011, 12:18 PM
wsar10
2003 WJ
If it is not letting you reset, than that could be a sign of a BCM issue.
(not necessarily a fatal one)
Are you having any other "overlooked" little electronically gremlins.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #11 of 14 Old 08-29-2011, 12:55 PM
MadMonk
I have the same problem. Sometimes it seems like the connection isn't working on the button. I sometimes have to tap on it several times to get it to reset.
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
post #12 of 14 Old 08-29-2011, 01:27 PM Thread Starter
vwbuge
finally got it to reset.
The only other thing I have going on is the air bag light. Does anyone have other suggestions for that issue? Other than clockspring? That is going to be my last resort.
vwbuge is offline
post #13 of 14 Old 08-29-2011, 02:56 PM
KayCeeJeep
Mine doesn't like to reset either. Not really sure how I got it to work last time, I just kept fiddling with it. Very annoying feature to a maintenance nut like me.
KayCeeJeep is offline
post #14 of 14 Old 11-20-2013, 11:36 AM
PrintBear
The Electronic Vehicle Information Center (EVIC) provides the vehicle operator with a user interface, which allows the selection of several optional customer programmable electronic features to suit individual preferences. The EVIC must be placed into its programming mode in order to view or change the programmable features. To enter the EVIC programming mode and to view or change the selected programmable features options, proceed as follows:
Turn the ignition switch to the ON position.
Depress and release the Menu push button. The first item in the programmable features menu list will appear in the EVIC display.
Momentarily depress and release the Menu push button to step through the programmable features list. Each programmable feature and its currently selected option will appear on the EVIC display in the sequence shown in the Programmable Features list that follows.
Momentarily depress and release the Step push button to step through the available options for the programmable feature being displayed.
The option that last appears in the display with a programmable feature before exiting the programming mode, becomes the newly selected programmable feature option.
The EVIC exits the programming mode and returns to its normal operating mode when the C/T (compass/thermometer) push button is depressed or when the end of the programmable features menu list is reached, whichever occurs first.
SERVICE INTERVAL - The options include from 1000 to 12000 kilometers in 1000 kilometer increments (2000 to 7500 miles in 500 mile increments). The default is 12000 kilometers (7500 miles). The selected distance becomes the interval at which the Perform Service warning message will be displayed by the EVIC. If a new distance is selected, a second programmable feature appears, RESET SERVICE DISTANCE? - The options include No and Yes. The default is Yes. When Yes is selected, the accumulated distance since the last previous Perform Service warning message will be reset to zero because the service interval has been changed. When No is selected, the distance until the next Perform Service warning message is reduced by the accumulated distance since the last previous message.
PrintBear is offline
perform service? kwoody30 WJ Grand Cherokee Forum 10 05-20-2011 12:37 PM
"Jeep", "Grand Cherokee", "4x4" and "V8" font question... Radosl81 WJ Grand Cherokee Forum 7 02-23-2011 03:37 PM
Evic "Service Vehicle" Question??? Amys2004 WJ Grand Cherokee Forum 5 04-19-2010 04:01 PM
Reseting the "Perform service" alert? Heracles WJ Grand Cherokee Forum 1 08-05-2007 01:36 PM
reseting perform service coops1105 WJ Grand Cherokee Forum 1 01-03-2004 07:52 AM
