PCV Hose help - JeepForum.com
post #1 of 4 Old 03-28-2012, 02:21 PM Thread Starter
Dezmondos
PCV Hose help
Hey everyone,
New on here - had a few jeeps in the past and just picked up a 2002 Grand Cherokee Laredo and need a bit of help.
When idling it sits around 2000rpm - then goes down to around 1000. I ve searched and am going to replace the Throttle position sensor and clean/replace the IAC valve. However I took a closer look this morning and someone has done a bad repair job on the pcv and hose - i tried to move the hose/box on top of the throttle body and it was brittle and cracked. i have been searching for about an hour and cannot find anywhere online that stocks the hose? Any tips where I could find one? I have found plenty of the pcv valves but not the hose.
Also i just noticed that the plastice clip on what I believe to be the 'kick down' cable has broken and the cable is just hanging there... do I have to replace the whole cable or can you just replace the clip.
Thanks in advance
Dezmondos is offline
post #2 of 4 Old 03-28-2012, 02:38 PM
14mpg
V8 or i6?
14mpg is offline
post #3 of 4 Old 03-28-2012, 05:31 PM
Bubba3200
Fuel hose a good option.
Bubba3200 is offline
post #4 of 4 Old 03-28-2012, 09:12 PM Thread Starter
Dezmondos
14mpg- V6
Thanks
Anyone know what this vent hose goes to? Janibeans WJ Grand Cherokee Forum 11 10-08-2012 01:27 PM
Coolant leaking out of small hose(Not a radiator hose) Pics. Lil_Ape WJ Grand Cherokee Forum 2 11-05-2011 05:14 PM
Where does this hose go? (PICS) seankeenan WJ Grand Cherokee Forum 5 06-10-2011 09:53 AM
Where does this hose go? (pic) EarpWJ WJ Grand Cherokee Forum 6 04-10-2011 05:38 PM
Radiator Hose cor-32 WJ Grand Cherokee Forum 19 04-08-2011 11:40 AM
