Passenger Grab Handle - JeepForum.com
post #1 of 10 Old 02-26-2012, 01:31 PM Thread Starter
mswansonpcs
Hello,
Since I purchased my 04 Jeep Grand Cherokee, one of the two screws holding the passenger grab handle have been missing. (the handle that a passenger might grab to get in/out of the vehicle)).
I figured I'd remove the other screen and then find a match to replace, but I can't get the screw out. It's a hex head, needing a socket, but I can't get a socket to fit in that hole that matches the screw size. I've tried needle nose pliers, but it's too tight.
The end of the bolt has a 98 on it. Any idea what size this screw/bolt is, or anyone figured out a good tool to remove it?
Thanks for any thoughts
mswansonpcs is offline
post #2 of 10 Old 02-26-2012, 05:29 PM
gtg413i
2003 WJ
take one of those small sockets that fits on the end of a driver that looks like a screw driver. Force it in there. <Read> push really hard and expand the plastic around there until you get in there. It is a pita for such a simple procedure, but it will fit if you force it.
Brian's Black Betty Build:
gtg413i is offline
post #3 of 10 Old 02-27-2012, 07:43 AM Thread Starter
mswansonpcs
Wj Grab Bar
Thanks for your response. That worked (just FYI to anyone else, it's a 6mm bolt).
Now the question is, where can I get another one just like it. It has #98 stamped on the bolt's head. I've been looking line, but no luck. (all results lead to a 1998 jeep grand cherokee, can't seem to search just for the bolt #)
I figure I'll try the local NAPA later today unless someone knows a better way.
Thanks
post #4 of 10 Old 02-27-2012, 12:23 PM
pinky2252s
You will find something to fit.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #5 of 10 Old 11-24-2013, 06:27 PM
geepers1960
2004 GC Limited. Mine were 5.5 MM. And I too used a socket driver (looks like a screwdriver). I had to spray the socket with WD-40 to get it into the access slot (tight fit).
geepers1960 is offline
post #6 of 10 Old 01-27-2014, 03:36 PM
JustSomeDude
I can confirm that this is definitely a 5.5mm hex on my 2004 WJ GC passenger and driver side grab bars. I will also add that a standard "deep drive" socket will fit in without any force whatsoever. See photo below....
I tried the two socket-drivers I had, but they were both 6mm or 1/4", and kept spinning on the bolt heads. I finally found a Duralast 5.5mm deep socket at AutoZone for $3.99. It fit like a charm and I pulled the A pillar grab handle covers off in a few seconds.
So glad I found this thread!!
2004 Jeep Grand Cherokee Laredo
3" IRO Lift Kit | Bilstein 5125 Shocks | JKS discos | JKS BPEs | IRO Adj Track Bar
Goodyear Duratrac 265/75/16
JustSomeDude is offline
post #7 of 10 Old 01-27-2014, 04:52 PM
grussell
Just go to your local Jeep dealer.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is online now
post #8 of 10 Old 01-27-2014, 06:31 PM
JustSomeDude
Did you mean to post in this thread?
What would we need to go to the Jeep dealer for?
post #9 of 10 Old 06-06-2015, 02:04 PM
gtg413i
2003 WJ
Had to do this again. It is not a size but that did work. It is 5.5mm or 7/33".
gtg413i is offline
post #10 of 10 Old 01-03-2017, 05:22 PM
JayIV
JayIV's Avatar
To add to the above, I can confirm that my 7/32" worked fine and I didn't have to force it in there.
2004 Overland
JayIV is offline
Rear Speakers and Grab Handle Lights Inop 2_From_NH WJ Grand Cherokee Forum 0 02-11-2012 07:58 AM
How to remove door handle??? hyperlightboard WJ Grand Cherokee Forum 1 01-10-2012 02:35 PM
Door Handle Question HookEm WJ Grand Cherokee Forum 3 08-06-2011 11:27 AM
Door Handle Lights gqmdl0617 WJ Grand Cherokee Forum 27 01-07-2011 01:14 PM
Grab Handle Overhead Lights thnksno WJ Grand Cherokee Forum 2 05-31-2010 10:13 AM
