Which parts for an axle seal replacement - JeepForum.com
post #1 of 4 Old 10-10-2011, 08:56 AM Thread Starter
motion
2003 WJ
Read through several threads and will be replacing a rear axle seal on a 2004 Grand Cherokee next weekend.... and want to make sure i get the right bearing / seal this week.
Looking on autozone / napa they seem to call the parts different things ... and have axle ID requirements.
Straight 6 2WD Grand Cherokee .... does this seem like the right parts?
Seal part number at autozone:
Part Number: 2146
Alternate Part Number: 2146
Bearing part number at autozone:
Part Number: SET36
Alternate Part Number: A-36
Thanks in advance.....
motion is offline
post #2 of 4 Old 10-10-2011, 10:03 AM
FirefightinWJ
Axle seals/bearings are the same for all WJ rear axles -- the 44a and 35 use the same parts.
I can't verify the numbers as I bought mine at Advanced Auto.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #3 of 4 Old 10-10-2011, 10:21 AM
WiCkeDuDe
I bought the SKF BR9 on rockauto. I know it was the right on and came with the retainer collar. It sells now for $24.79. The seal I use is the 2146. I think the ones I bought were Timken and worked well. They are about $6 on rockauto.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #4 of 4 Old 10-17-2011, 08:20 AM
Satrebil
Excellent thread. Just blew my rear axle bearing and seal and need to replace it.
Satrebil is offline
transfer case output seal replacement procedure, am i messing anything ? straty1987 WJ Grand Cherokee Forum 14 12-09-2014 10:22 PM
Wj crank seal replacement thisguyhasadd2 WJ Grand Cherokee Forum 0 09-16-2011 05:31 PM
axle seal pjkatz04 WJ Grand Cherokee Forum 21 07-10-2011 02:30 PM
Does this look like a bad axle seal? MileHighJeep WJ Grand Cherokee Forum 28 05-01-2011 07:32 PM
rear main seal replacement RKOTAREK WJ Grand Cherokee Forum 3 09-26-2010 10:24 PM
