P1682/ battery getting drained - JeepForum.com
post #1 of 3 Old 06-09-2014, 03:44 PM Thread Starter
Prickett10
Took a hunting trip (950 miles round trip) and on the return trip I started noticing I would have to depress the gas pedal alot farther to get it to shift into over drive. A little later I noticed my volt meter was hovering just above 10 volts. Then the check gauges light chimes. Continued dropping volts right up to the driveway where it rested. Dead. (side note, this was at night = dim headlights) the jeep started this morning * slow to crank* and jumped right up to 14 volts then slowly started dropping again. I checked the codes and pulled the 1682 code. So, any ideas?
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #2 of 3 Old 06-09-2014, 11:23 PM
bradywgn71
bradywgn71's Avatar
P1682 - Charging System Voltage Always Low Conditions
Engine running at over 1152 rpm and the PCM detected the Charging system volts was more than 1v below the target value for 25 seconds (target value is 13.4-14.8v)
Looks like the alternator died. I'd have that checked since it's pretty much a freebie. I think the voltage regulator is part of the ECM. The only other thing I can think of that might affect charging is the battery temp sensor.
And of course.... check that your battery cables are clean and tight.
Batteries will self charge a bit when at rest so it doesn't surprise me that it had enough juice the next morning to slow crank the engine but then immediately started to lose voltage.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 3 Old 06-10-2014, 05:56 AM Thread Starter
Prickett10
Gave the alt a good ole love tap then jumped her. I'm a lame a** thanks any how.
