P0441 and P0443 codes - JeepForum.com
post #1 of 4 Old 10-05-2013, 03:43 PM Thread Starter
walton8799
What does this mean!! Lol
walton8799 is offline
post #2 of 4 Old 10-05-2013, 03:51 PM
WJ4x4LIFE
When is the last time you fueled up and did you overfill it? Did the codes come up afterward or before hand fueling up?
WJ4x4LIFE is offline
post #3 of 4 Old 10-05-2013, 04:20 PM Thread Starter
walton8799
Never really overfilled I don't believe, it's been on for over multiple stops at the gas station
post #4 of 4 Old 10-05-2013, 04:57 PM
WJ4x4LIFE
CODE: PO443
Evaporative Emission Control System Purge Control Valve Circuit
An open or shorted condition detected in the EVAP purge solenoid control circuit. Check the charcoal canister for fuel saturation If the vehicle has been overfueled, then there is a chance that liquid fuel can enter the canister and cause drive problems or emission related problems.
CODE: P0441
Evaporative Emission Control System Incorrect Purge Flow
Insufficient or excessive vapor flow detected during evaporative emission system operation. If after performing all powertrain test for P0441 with results that appear to be normal/test pass, check for fuel in the purge canister. If there is fuel in the purge valve, insure that the vehicle owner is not overfilling the fuel tank.
Give the canister on 443 a shot first, then move to the 441...The instructions are right out of the manual and wjjeeps.com. Gives us some feedback, once revised instructions above are done.
