P0305 cylinder 5 misfire - JeepForum.com
post #1 of 6 Old 03-14-2014, 08:16 AM Thread Starter
01wjv8
I keep getting this fault code. I tested the plug, and there is a spark. The spark plug is wet, so the fuel is getting there. Is there a chance this could be an electrical problem? If so, what do i do?
01 wj v8 limited
01wjv8 is offline
post #2 of 6 Old 03-14-2014, 08:25 AM
snorander
bad coil?
snorander is offline
post #3 of 6 Old 03-14-2014, 08:31 AM Thread Starter
01wjv8
Forgot to say, tried replacing the coil with a brand new one. Did not change a thing.
01wjv8 is offline
post #4 of 6 Old 03-14-2014, 08:44 AM
gloomis1988
I'm having similar issue and car jeep will run fine for a while and start miss firing and run hard for a bit then smoothen out I also replaced the coil pack
gloomis1988 is offline
post #5 of 6 Old 03-14-2014, 08:59 AM
ChrisHager
Administrator
ChrisHager's Avatar
Misfire Diagnosis Guide
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6 of 6 Old 03-14-2014, 09:06 AM
gloomis1988
