p0203 Help! - JeepForum.com
post #1 of 35 Old 10-10-2011, 12:09 AM Thread Starter
dgladdWJ
p0203 Help!
My 2000 WJ I6 4L is giving me a P0203. I have swaped injector 3 with injector 4. The code stayed the same and did not move with the injector. I get 15ohms of resistance at the conector plug on the injector. I was wondering if anyone could give me some more ideas. i don't know where to go from here. Thank you for your time.
dgladdWJ is offline
post #2 of 35 Old 10-10-2011, 12:29 PM Thread Starter
dgladdWJ
I would love some ideas even if its just a total shot in the dark.
thank you
dgladdWJ is offline
post #3 of 35 Old 10-10-2011, 03:32 PM
pjkatz04
Maybe trying resetting the mil and if it comes up again then see which injector---if it's the same or not.
2002 4.7, Selec-Trac, K&N FIPK II, JetChip Stage 1.
pjkatz04 is offline
post #4 of 35 Old 10-11-2011, 08:37 PM Thread Starter
dgladdWJ
I reset it and it still comes back as cyl #3. I baught a test light tonight and plugged it into the conector and the light comes on and flashes like it should as if it where to send power to the injector. It looks the same as it does when I plug it into any other connectors. Could the P0203 code mean that the coil pack has gone bad. I have aready swaped plugs aroung no change. I am even more lost after the test light. it doesn't make any sence.
dgladdWJ is offline
post #5 of 35 Old 10-13-2011, 10:20 PM Thread Starter
dgladdWJ
Now the oil pressure is pegged high. WTF is going on here????????????????
dgladdWJ is offline
post #6 of 35 Old 10-13-2011, 10:25 PM
pjkatz04
I'm not sure about the code. But for the pressure just turn the jeep to the ON position but do NOT start it. If the pressure reads anything but zero then the sensor is bad. That's a cheap and easy fix.
pjkatz04 is offline
post #7 of 35 Old 10-13-2011, 10:27 PM
pjkatz04
Is the engine running ok and ur just getting a code or is it running rough or something?
pjkatz04 is offline
post #8 of 35 Old 10-13-2011, 10:34 PM Thread Starter
dgladdWJ
no it not running ok. cyl 3 is not fireing at all.
dgladdWJ is offline
post #9 of 35 Old 10-13-2011, 10:46 PM
pjkatz04
yea dude thats strange. someone on here with some more experience can prob help tho. hang tight!
pjkatz04 is offline
post #10 of 35 Old 10-13-2011, 11:01 PM Thread Starter
dgladdWJ
I sure hope so. Thanks man.
dgladdWJ is offline
post #11 of 35 Old 10-13-2011, 11:04 PM
pjkatz04
did u check the oil pressure sending unit to see if the sensor is bad?
pjkatz04 is offline
post #12 of 35 Old 10-13-2011, 11:24 PM Thread Starter
dgladdWJ
not yet. is there any way to test it or do i just replace it?
dgladdWJ is offline
post #13 of 35 Old 10-13-2011, 11:40 PM
MeanGreenZJ
Did you check the wiring harness just behind the valve cover near the firewall? The valve cover stud can rub into the wiring harness and do all kinds of crazy things when the wiring gets shorted.
MeanGreenZJ is offline
post #14 of 35 Old 10-14-2011, 04:25 PM Thread Starter
dgladdWJ
Yes, it's been checked.
dgladdWJ is offline
post #15 of 35 Old 10-14-2011, 05:33 PM
23bananas
I had about 3-4 cylinders spitting out codes, in addition to the TPS. Once that got replaced those codes magically vanished. Not sure if it'll help, but if the TPS is also in the code readout i'd do that first.
23bananas is offline
P0203-help please.......(and P1282) philip1972 WJ Grand Cherokee Forum 1 10-06-2011 12:15 PM
