P0161 Code- location and which 02 sensor to buy? - JeepForum.com
post #1 of 5 Old 07-20-2017, 12:59 PM Thread Starter
2cflyr
ok, so i did use the search function and it's still pretty vague as to the location and which one. from what Ive gathered from searches:
1- buy the Delphi as its OEM
2- they have different wire lead lengths
3- its in a different location on California cars- before or after the catalytic converter
so, I know that there are two in the exhaust runners right in front of the firewall, and there is apparently a third in front of the muffler.
the questions:
1- which is the right O2 sensor to get?
2- location?
3- why is there a different part/O2 sensor for cylinders 1,2, 3 and 4, 5, 6?
Thanks.
2cflyr is offline
post #2 of 5 Old 07-20-2017, 07:36 PM
Mattyjm
Mattyjm's Avatar
First thing to do before replacing any O2 sensors is to check your #16 fuse in the Power Distribution Center under the hood. This will be a 10 Amp fuse. Make sure it's not blown before replacing any sensors.
There aren't individual sensors for individual cylinders. On your WJ with Cali. emissions, there are four O2 sensors. Two are located on the exhaust manifold on the driver's side of the engine. Two more are located before and after your catalytic convertor. These sensors are labeled as Bank 1/Sensor 1, or Bank 1/Sensor 2. Bank 1 covers cylinders 1-22-3. Bank 2/Sensor1 and Bank 2/ Sensor2 cover cylinders 4-5-6.
Your #1 sensors for either bank are up on the manifold. Your sensor 2s are downstream around the CC. Hope this helps you, buddy.
whispering spookily...." I see Grand Cherokees. I see them ALL the time...."
Mattyjm is offline
post #3 of 5 Old 07-21-2017, 09:32 AM Thread Starter
2cflyr
excellent. thank you for the explanation.
2cflyr is offline
post #4 of 5 Old 07-21-2017, 09:49 AM
BDW
P0161 is bank 2 sensor 2. Rear cat, after the cat. Specifically "Oxygen sensor heater element malfunction".
Parts guy at the dealer told me they were all built with three cats and four sensors (CA emissions).
04 WJ 4.0/NP242, 3" OME, Bilsteins, 255/75/17 & JKR wheels, 44A, 4.56, ARB lockers, & more
BDW is offline
post #5 of 5 Old 07-21-2017, 08:27 PM
Uniblurb
Uniblurb's Avatar
Thanks.
Sure you don't mean Denso brand rather than Delphi? Not exactly sure on the 4.0 but on my 04 4.7 Denso was OE and that's what I used as replacements.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
